I'm struggling to get the the -w -c arguments to work properly in the check_temp_watchdog15.sh plugin. I think it's looking for temperature ranges. I'm not sure what format is required. Does the script need to modified?
check_temp_watchdog15.sh plugin alert ranges
hillhealthcenter
Thanks so much,
Tom
Tom
Re: check_temp_watchdog15.sh plugin alert ranges
The ranges can be specified as described here: https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT
hillhealthcenter
I'm all set.
In our case, the magic statement was -w50:85.
You can lock the post, if you'd like.
Thanks so much,
Tom
Tom
