API Issue
russell.it
API Issue
Post by russell.it »
Hey all,
I am having some issues with API's in our nagiosxi instance. I have added
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
To the ssl.conf file above the </VirtualHost>
Which fixed the first error I was getting (page not found) now I am getting a "NoEndpoint:" if I tail the httpd error log I get "Php Notice: Undefined inex: request in /usr/local/nagiosxi/html/api/v1/index.php on line 37"
Any ideas on where to look next?
I have tried a few of the example links from the "Help with Nagios XI" page. I have checked my user is a full admin and has api access enabled.
Re: API Issue
What is the version of Nagios XI that you are currently using? You are not using a URL that goes through a proxy, are you?
Please show us the exact URL that you are using to get the API, minus the API key. Thank you!
russell.it
Re: API Issue
https://nagios-server/nagiosxi/api/v1/s ... Z&pretty=1 the result of that url is "NoEndpoint:"
Currently running 5.4.13
No proxy
Re: API Issue
This seems like an apache config issue. We need to do some more digging into it to be sure. Can you post the entire /etc/httpd/conf/httpd.conf, /etc/httpd/conf.d/nagiosxi.conf, and /etc/httpd/conf.d/ssl.conf files, so that we can review them?
russell.it
Re: API Issue
Configuration files uploaded as requested. :)
Re: API Issue
Remove the following lines from the nagiosxi.conf:
RewriteCond %{SERVER_PORT} =80
RewriteRule ^(.*) https://%{HTTP_HOST}/nagiosxi [L,R]
save, exit, and restart apache:
service httpd restart
Let us know if this fixed the issue. Thank you!
russell.it
Re: API Issue
Still the exact same error.
NoEndpoint:
Tested with a few of the REST API test url's found in the docs section of our nagiosxi install.
cdienger
Re: API Issue
Post by cdienger »
There's a typo in ssl.conf. Change:
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request$1 [QSA,NC,L]
to:
russell.it
Re: API Issue
That was it missing = sign.
Thanks heaps.
I have tested both get and post methods with no issues.
Happy for this topic to be locked.
