I tried to run this plugin below plugin
./check_iftraffic64.pl -H 192.68.2.1 -C public -i 5 -B -b 100 -u m --32bit
it is not showing anything ,not even error also
is there any mistake in my command please reply
problem with network I/o
Re: problem with network I/o
Does interface "5" exist? What if you run this
Also are you sure you have the right IP, community string, and SNMP is enabled ion this server?
Also, maybe you need to add the version..
What if you run this? Do you get anything back?
./check_iftraffic64.pl -H 192.68.2.1 -C public -i 5 -B -b 100 -u m --32bit -d 4Also, maybe you need to add the version..
