The script that failed was: './0-repos'
andrewatmacys
I'm trying to do a full clean install of Nagios XI on a server and the install is failing at this point. I have followed all the directions, but it doesn't seem to want to continue past this. Looking around, it seems the repos are not set up, but how do I do this so that it can continue the install?
npolovenko
- Support Tech
Re: The script that failed was: './0-repos'
Hello, @andrewatmacys.
What Operating system are you trying to install the Nagios on?
Can you upload the install.log file in the ticket?
Also, please run:
And show us the output.
Also, please run:
yum repolistAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
andrewatmacys
Redhat Linux 7.0
Loaded plugins: langpacks, product-id, rhnplugin, search-disabled-repos,
: subscription-manager
*Note* Spacewalk repositories are not listed below. You must run this command as root to access Spacewalk repositories.
repolist: 0
Where can I find the install.log?
repolist: 0
andrewatmacys
I found it, I believe.
So here is the actual error
you need to add the optional channel to install Nagios XI on RHEL
run the following as root
then perform the install again
Configuring Repos...
package centos-release is not installed
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-7-server-optional-rpmsrun the following as root
yum-config-manager --enable rhel-7-server-optional-rpms-
andrewatmacys
Same problem on the outward appearance after running the above command. I am including the new install.log.
This doesn't look added, did you follow the commands adding your redhat username/password?
If so, can you run the following this time as root
sudo yum repolist-
andrewatmacys
The channel was not added, once added everything went well. Thank you! This can be closed now.
Glad to hear it is resolved.andrewatmacys wrote:The channel was not added, once added everything went well. Thank you! This can be closed now.
