Issue with false critical values on Virtual Machines
Ivajlo911
Post by Ivajlo911 »
we have a problem with false critical values coming from Nagios on a few virtual machines. Here is one example:
Service: L3CSGHVI CPU Usage
Host: vCSSGH
Address: ......
State: CRITICAL
Info:
ESX3 CRITICAL - L3CSGHVI cpu usage=-0.01 %
Date/Time: 2018-06-07 08:25:1
Service: L3CSGHVI Memory
Host: vCSSGH
Address: ......
State: CRITICAL
Info:
ESX3 CRITICAL - L3CSGHVI mem usage=-0.01 %
Date/Time: 2018-05-25 05:43:17
Details of our implementation:
CentOS Linux release 7.4.1708 (Core)
Manual Install of Nagios XI
No special configurations on our system, ie; is Gnome installed
We are not using a proxy
We are using Nagios XI 5.4.13.
Re: Issue with false critical values on Virtual Machines
Can you show the full command your services?
I think this may be an anomaly in the ESX api, which you can probably get arrounf by setting your warning and critical thresholds to make negative numbers be OK
So for example if you had a warning/critical threshold set to 80 change it to ~:80 this means from negative infinity to 80 are OK and above is not.
Ivajlo911
Post by Ivajlo911 »
I would avoid such workarounds if possible.
These are the commands:
/usr/local/nagios/libexec/check_esx3.pl -H "10.10.7.220" -f "/usr/local/nagiosxi/etc/components/vmware/vCSSGH_auth.txt" -N "L3CSGHVI" -l "CPU" -s usage -w 80% -c 90%
ESX3 OK - "L3CSGHVI" cpu usage=18.50 % | cpu_usage=18.50%;80;90+
/usr/local/nagios/libexec/check_esx3.pl -H "10.10.7.220" -f "/usr/local/nagiosxi/etc/components/vmware/vCSSGH_auth.txt" -N "L3CSGHVI" -l "MEM" -s usage -w 80% -c 90%
ESX3 OK - "L3CSGHVI" mem usage=71.99 % | mem_usage=71.99%;80;90
cdienger
Post by cdienger »
Is the behavior frequent or consistent? The output in the last post looks to be normal. I tested with the 6.7.0 vmware sdk and haven't been able to reproduce yet. Run "/usr/bin/vmware-cmd --version" to find the version that is installed on the XI system.
Also, here is a screenshot of my check settings just to make sure you're running something similar.
Ivajlo911
Post by Ivajlo911 »
behavior is more consistent then frequent. Happens from time to time - every two or three days for two particular VMs.
Also we use 6.5.0 vmware sdk. Do you think we should update.
Our settings are the same as yours.
cdienger
Post by cdienger »
Yes, I think it would be worth it to update. As was pointed out, this is likely something related to the API and is hopefully addressed in the update.
Ivajlo911
Post by Ivajlo911 »
after update problem continues:
***** Nagios XI Alert *****
Nagios has detected a problem with this service.
Notification Type: PROBLEM
Service: L3CNS02 CPU Usage
Host: vCSSGH
Address:
State: CRITICAL
Info:
ESX3 CRITICAL - L3CNS02 cpu usage=-0.01 %
Date/Time: 2018-06-18 04:57:47
cdienger
Post by cdienger »
Please confirm the plugin and wizard version. The plugin version can be seen with:
/usr/local/nagios/libexec/check_esx3.pl --version
and the wizard version can be found under Admin > System Extensions > Manage Config Wizards > VMware. The latest wizard version is 1.7.1 and you can upgrade to that version by clicking the Check for Updates and Intall Updates buttons found on the top of the page.
Ivajlo911
Post by Ivajlo911 »
Wizard version is: 1.6.9
The version of the plugin is:
[root@l3cnagint ~]# /usr/local/nagios/libexec/check_esx3.pl --version
check_esx3.pl 0.2.1
cdienger
Post by cdienger »
Is that a typo or does it actually show 0.2.1? My machien shows 0.7.1. In either case, try upgrading the wizard which should have the latest plugin as well.
