Configure SNMP Traps in Nagios?
riahc3
Post by riahc3 »
How do I configure SNMP Traps in Nagios?
Ive imported the MIB, set up the trap listener….but….
cdienger
Re: Configure SNMP Traps in Nagios?
Post by cdienger »
Have you setup snmptt.conf to use a trap handler to send the traps to Nagios for processing? Have you setup and passive checks in Nagios for it? http://askaralikhan.blogspot.com/2010/1 ... agios.html is outdated but has some good information. For example, you can use the trap handler snmptraphandling.py found in http://assets.nagios.com/downloads/supp ... ns.tar.bz2 instead of what they use. The article also covers setting up a passive check.
rhassing
Post by rhassing »
There is some information on:
http://mona.deltics.info/snmptrapping/
Rob Hassing
cdienger
Post by cdienger »
Thanks for the additional link, @rhassing.
@riahc3, let us know if you have any further questions for us :)
riahc3
Post by riahc3 »
Well, the packages in the outdated tutorial are already here: https://assets.nagios.com/downloads/nag ... ios_XI.pdf so....
Anyways…
This is for CentOS 5.....holy shit. Im mean thats old. I cant find the snmptrapd.options file. Seeing as this is a production server, I cant play around and test.
Im not sure why Nagios makes this so difficult to setup.
I use SNMPv3 so I cant disable authorization.
There is a lot outdated in this tutorial...sorry.
It shouldn't matter the OS release is in the instructions, the commands should be the same.
Do you have a specific issue you need help on?
Is this a better tutorial?
https://paulgporter.net/2013/09/16/nagios-snmp-traps/
