Tempature Alert
lance.peterson
Tempature Alert
Post by lance.peterson »
Is there a room temperature alert that can integrate easily into Nagios for monitoring? I'll get a standalone one if I have to but figured I'd asked if something played nice with Nagios.
Thanks!
npolovenko
Re: Tempature Alert
Post by npolovenko »
@lance.peterson, Are you asking for a recommendation on a model of the temperature sensor? As long as you can run some kind of script against the sensor and return the temperature you will be able to integrate it. Last year I integrated a cheap 5$ sensor for raspberry pi and it worked well.
