Hi Team,
How can i disable particular interface from device in NagiosXI?
How to disable interface from device
npolovenko
- Support Tech
Re: How to disable interface from device
Hello, @ganeshkagde. Are you talking about the network switch and router wizard?
ganeshkagde
Hi npolovenko,
Any device interface. if there is any different procedure for different device then also please let me know.
By "disable" do you mean disable monitoring of a device?
you can do that in the Configure -> CCM -> Service -. Find service -> Edit Uncheck Active
Save
Apply Configuration
Save
Apply Configuration
