check_cpu_perf.sh throwing unary operator errors
rjmon
Post by rjmon »
This plugin is failing on RHEL 6.9
$ bash -version
GNU bash, version 4.1.2(1)-release (x86_64-redhat-linux-gnu)
./check_cpu_perf.sh: line 200: [: -lt: unary operator expected
./check_cpu_perf.sh: line 204: [: -lt: unary operator expected
199 #Display CPU Performance with alert
200 if [ ${SARCPUIDLE} -lt $2 ]
201  then
202                 echo "CRITICAL: $CPU"
203                 exit 2
204  elif [ $SARCPUIDLE -lt $1 ]
205                  then
206                   echo "WARNING: $CPU"
207                   exit 1
208          else
209                   echo "OK: $CPU"
210                   exit 0
211 fi
cdienger
Re: check_cpu_perf.sh throwing unary operator errors
Post by cdienger »
One of the two variables in the if statement isn't set properly.From the output it looks like it's probably ${SARCPUIDLE}. You can use "set -xv" before and "set +xv" after this section to enable some debugging.
http://tldp.org/LDP/Bash-Beginners-Guid ... 02_03.html
rjmon
Post by rjmon »
Here is the debug.. I think it is failing because of that log file is missing..
$ ./check_cpu_perf.sh 20 10
Cannot open /var/log/sa/sa11: No such file or directory
 then
                exit 2
                 then
                  exit 1
         else
                  echo "OK: $CPU"
                  exit 0
fi
+ '[' -lt 10 ']'
./check_cpu_perf.sh: line 201: [: -lt: unary operator expected
+ '[' -lt 20 ']'
./check_cpu_perf.sh: line 205: [: -lt: unary operator expected
+ echo 'OK: CPU Idle = % | CpuUser=; CpuNice=; CpuSystem=; CpuIowait=; CpuSteal=; CpuIdle=:20:10'
+ exit 0
rjmon
Post by rjmon »
Issue is resolved. This was due to sar service was not started after our recent patch.
Great to hear it! Did you have further (related) questions or are we good to lock this up?
rjmon
Post by rjmon »
Thanks. I am good you can close this.
