Which user is login on which computer
alidar
Post by alidar »
Hello
Can we see that which user is login on which computer by nagios core?
Regards
Re: Which user is login on which computer
Post by mcapra »
Sure, but the actual implementation would depend on the authentication method being used (sometimes) as well as the operating system itself (all the time).
Here's an older post I made where I do a Windows-based "logged in users" check via Powershell using and older NSClient++ version as the agent:
https://support.nagios.com/forum/viewto ... 58#p191894
You could expand on that Powershell following the nagios plugin development guidelines if you wanted richer output.
There's a few different options available on the Nagios Exchange as well:
https://exchange.nagios.org/index.php?o ... 0on%20user
cdienger
Post by cdienger »
Thanks for the assist, @mcapra!
alidar
Post by alidar »
In old post, I copied this script. Can you tell me where I will put this script.
The following powershell script (I named it check_users.ps1) worked against my Windows 7 machine:
$computername = 'localhost'
$user = Get-WMIObject Win32_Process -filter 'name="explorer.exe"' -computername $ComputerName |
ForEach-Object { $owner = $_.GetOwner(); '{0}\{1}' -f $owner.Domain, $owner.User } |
Sort-Object | Get-Unique
if(!$user) {Write-Host ""}
else {Write-Host $user}
My NSClient++ (0.4.x) command configuration:
check_users = cmd /c echo scripts\check_users.ps1; exit($lastexitcode) | powershell.exe -command -
I am using NCPA client. How I can use on NCPA?
Post by mcapra »
Here's the official documentation for using custom scripts/plugins with NCPA:
https://support.nagios.com/kb/article/n ... a-722.html
It has a section which includes a sample Powershell script. Let us know if some part of that documentation is unclear or isn't working correctly.
Thanks @mcapra for the help. @alidar let us know if you have any further questions.
