Nagios return 0byte string from bash script
raja2206
Post by raja2206 »
We have configured shell script to mointior unity storage via nagios, the script is working fine via CLI, but it is 0 byte output via nagios
# ls -la check_unity.sh
-rwxr-xr-x 1 nagios nagios 681 Jun 11 11:19 check_unity.sh
 # cat check_unity.sh
#!/bin/bash
ucli=/usr/bin/uemcli
host=$1
user="$2"
password="$3"
check_path="$4"
if [ "`$ucli -d $host -user $user -password $password $check_path show -output csv | sed '1d' | cut -d"," -f5 | sed -e 's/\"//g' -e 's/\s.*//g' | sort | uniq | awk '{if (NR == 4) print}'`" == "OK" ] ; then
        echo "OK - no faults detected"
        exit 0
else
      echo "UNKNOWN - Unisphere CLI returned an error, unable to perform check"
       exit 1
fi
cfg file :
        use                     array-service ; Inherit values from a template
        service_description     check unity Status
        host_name               unity5400   ; hostname the service is associated with
        check_command           check_unity_status!xxx!ppp!/env/ps
        normal_check_interval   10              ; Check the service every 60 minutes under normal conditions
command.cfg
#check_unity_general
        command_name    check_unity_status
        command_line    $USER2$/check_unity.sh $HOSTADDRESS$ $ARG1$ $ARG2$ $ARG3$
Can you please anyone help on this issue.
Reason: Please use [code][/code] tags around code output
Re: Nagios return 0byte string from bash script
Can you run the command form the CLI as the nagios user?
sudo su nagios -c '/full/path/to/script/check_unity.sh xxx.xxx.xxx.xxx xxx ppp /env/ps'
raja2206
Post by raja2206 »
HI, please find the output.
#/opt/nagios/libexec # sudo su nagios -c '/opt/nagios/libexec/check_unity.sh unity500 Monitor password /env/ps'
Note : my password has special character '%' in the middle
raja2206 wrote:Note : my password has special character '%' in the middle
This makes a difference....
Lets set $ARG2$ to be 'ppp' where ppp is your password, wrapping it in single quotes
raja2206
Post by raja2206 »
I have updated the .cfg file, but still no output from nagios. However from command is working fine
host_name unity500 ; hostname the service is associated with
check_command check_unity_status!Monitor!'pppp%ppp'!/env/ps
#/opt/nagios/etc # sudo su nagios -c '/opt/nagios/libexec/check_unity.sh unity500 Monitor 'pppp%ppp'' /env/ps'
Note : it is necessary to restart nagios service for this change ?
raja2206 wrote: Note : it is necessary to restart nagios service for this change ?
Yes, but you should be making the change in Configure -> CCM and then Apply Configuration not directly in the .cfg as this will get overwritten by the CCM the next time you Apply Configuration.
raja2206
Post by raja2206 »
I have restarted the nagios services, still same error.
command.cfg file
Monitor config file
I have updated the script with echo output :
#!/bin/bash
#ucli=/opt/emc/uemcli/bin/uemcli.sh
host=$1
user="$2"
password="$3"
check_path="$4"
exit 0
else
C="`$ucli -d $host -user $user -password $password $check_path show -output csv | sed '1d' | cut -d"," -f5 | sed -e 's/\"//g' -e 's/\s.*//g' | sort | uniq | awk '{if (NR == 4) print}'`"
echo "C= $C"
# echo "UNKNOWN - Unisphere CLI returned an error, unable to perform check"
exit 1
fi
output in nagios is emptry
C=
looks like when it is running you are getting to the else clause.
Unfortunately we can''t really debug this from here as we don't have these systems.
gormank
Post by gormank »
Try commenting the first echo and uncommenting the second. Note that a plugin returning nothing on STDOUT is not an error and that the return status ($?) is the significant part.
gormank wrote:Try commenting the first echo and uncommenting the second. Note that a plugin returning nothing on STDOUT is not an error and that the return status ($?) is the significant part.
Except this isn't actually returning nothing, it is returning
C=
