Connection timed out after 30 sec
Gonela
Post by Gonela »
Hi Team,
i'm getting Connection time out after 30 sec.
And no luck , If i change 30 sec to 120 sec
May i know exact issue for connection timed out . What i need to check from nagios end.
cdienger
Re: Connection timed out after 30 sec
Post by cdienger »
How are you increasing the timeout? Have you tried running the command from the command line?
The global timeout values likely need to be increased as well. Search for "host_check_timeout" and "service_check_timeout" in https://support.nagios.com/kb/print-617.html to increase them.
Gonela
Post by Gonela »
Time out seconds increased in command definition and Also ports were opened But still same issue.
We changed all parameters using this :https://support.nagios.com/kb/print-617.html . There is no luck .
May i know the causes of this issue?
cdienger
Post by cdienger »
What command are you running that is producing the timeout? Does it work from the command line? Please provide screenshots of the command and output.
Gonela
Post by Gonela »
Thanks for update.
issue resolved from my end.
Please close this thread
