Hi.
I am working with this plugin check_nwc_health and if I execute the command
./check_nmw_health --hostname x.x.x.x --mode pool-connections --community XXXX
It shows me all the pool connections. The problem is that I have hundreds of pools and I just want you to show me the pools that are down.
Please help
Thank you
check_nwc_health pools down
Re: check_nwc_health pools down
Can you share the output of the command? I don't have a device to test this third party plugin against and the output may give us some clues as to what options to run with it that may give the desired output.
That said, I see there is a --report option to give a shortened output. Does this give you what you're looking for?
firanagios
Hello
That may be a good option, but I add --report 100 for example and it gives me the same output as if I do not write --report
I do not know if I'm doing it right ... this is the command that I execute
./check_nmw_health --hostname x.x.x.x --mode pool-connections --community XXXX --report 100
Thank you very much for the help
I took a look at the plugin and there is not an option to just output the pools that are down.
You would have to modify the plugin to get that functionality or ask the author to do that for you.
firanagios
Ok, thank you
Locking
