Is there a check that will look at other checks and report if one or more is critical?
For instance:
If I'm monitoring ping and http on www1 through www8. If they are all OK, nothing happens.
If www3 goes critical on its http check, I want the "roll-up" check to alert me that something is wrong.
If all the servers are nuked and reporting as critical only ONE alert should be sent to the "roll-up" contacts.
Is this possible now?
"Roll-Up" monitor?
Re: "Roll-Up" monitor?
You can create groups in BPI using checks that may not have notifications enabled, and then just report on the BPI group as a whole.
https://assets.nagios.com/downloads/nag ... BPI_v2.pdf
