Hello
Good evening.
After upgrading NLS to version 2.0.2, users are complaining that they can not remove the columns from the data tables.
We verify that the items are appearing white; equal to background color; so users can not view and remove the columns.
NLS - Remove Table Column
ssoliveira
ssoliveira
Re: NLS - Remove Table Column
Perhaps the simplest solution is to just remove the "label" parameter from the "class" attribute of the "span" object; in the list of columns. Or, configure the css correctly (if it does not affect other things).
This is addressed in an upcoming release expected in the next couple of weeks.
