Network 8.4 on Windows + Nagios XI
biswajit.banerjee
Hi Support ,
We are stuck with Network 8.4 on Windows + Nagios XI . Any suitable Plugin with documentation .
we have tried https://exchange.nagios.org/directory/P ... PE/details
Kindly help .
TIA
Regards
Biswajit
Kindly help .
TIA
Regards
Biswajit
Re: Network 8.4 on Windows + Nagios XI
Sorry, I am not familiar with Network 8.4.
What are you trying to accomplish?
biswajit.banerjee
My Apologies , It is Dell EMC Networker .
We are trying to monitor windows networker backup server job status .
And did the plugin not get you what you need? Looks like it was designed to run under NSClient++
I see the description has this
which should really be
check_networker_job=c:exploitscriptsstartallnagiosCheck_Networker_Job.cmd $ARG1$Code: Select all
check_networker_job=c:\full\path\to\script\Check_Networker_Job.cmd $ARG1$-
biswajit.banerjee
The plugin is failing to give output .
# ./check_nrpe -H IP -c checknetworkerjob
The command (checknetworkerjob) returned an invalid return code: 255
can you share your nsclient configuration?
Also, can you confirm the plugin works if you run it from the command line on the windows server?
biswajit.banerjee
nsclient.ini
______________________________________________________
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = public
; Undocumented key
allowed hosts = 127.0.0.1,::1, 172.16.5.78
port = 12489
[/settings/NRPE/server]
allow arguments = true
; Undocumented key
ssl options = no-sslv2,no-sslv3
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
[/modules]
; Undocumented key
CheckExternalScripts = enabled
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NSClientServer = 1
; Undocumented key
NRPEServer = enabled
[/settings/external scripts]
checknetworkerjob=scripts\Check_Networker_Job.bat EVS01CRS01
time=scripts\time.bat
[/settings/log]
file name = nsclient.log
level = debugCode: Select all
C:\Program Files\NSClient++>nscp test
L client Module: CommandClient
L client Command:
L client Extra Query:
L client Mode: 3
L client Boot: 1
L client Load All: 0
L client Warning module and boot specified only THAT module will be loaded
L client Arguments:
D core NSClient++ 0.4.4.23 2016-04-05 x64 Loading settings and logger...
D core Settings not ready so we cant lookup: base-path
D core Settings not ready so we cant lookup: exe-path
D settings Boot.ini found in: C:\Program Files\NSClient++/boot.ini
D core Settings not ready so we cant lookup: shared-path
D settings Activating: ini://${shared-path}/nsclient.ini
D settings Creating instance for: ini://${shared-path}/nsclient.ini
D settings Loading: C:\Program Files\NSClient++/nsclient.ini
D core NSClient++ 0.4.4.23 2016-04-05 x64 booting...
D core Booted settings subsystem...
D core On crash: restart: NSCP
D core Archiving crash dumps in: C:\Program Files\NSClient++/crash-dumps
D core booting::loading plugins
D core Found: CheckDisk
D core Found: CheckEventLog
D core Found: CheckExternalScripts
D core Found: CheckHelpers
D core Found: CheckNSCP
D core Found: CheckSystem
D core Found: NRPEServer
D core Found: NSClientServer
D core C:\Program Files\NSClient++/modules\CheckDisk.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckDisk.dll
D core C:\Program Files\NSClient++/modules\CheckEventLog.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckEventLog.dll
D core C:\Program Files\NSClient++/modules\CheckExternalScripts.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckExternalScripts.dll
D core C:\Program Files\NSClient++/modules\CheckHelpers.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckHelpers.dll
D core C:\Program Files\NSClient++/modules\CheckNSCP.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckNSCP.dll
D core C:\Program Files\NSClient++/modules\CheckSystem.dll.dll
D core adding C:\Program Files\NSClient++/modules\CheckSystem.dll
D core C:\Program Files\NSClient++/modules\NRPEServer.dll.dll
D core adding C:\Program Files\NSClient++/modules\NRPEServer.dll
D core C:\Program Files\NSClient++/modules\NSClientServer.dll.dll
D core adding C:\Program Files\NSClient++/modules\NSClientServer.dll
D core Loading plugin: CheckDisk
D core Loading plugin: CheckEventLog
D core Loading plugin: CheckExternalScripts
D ext-script No aliases found (adding default)
D core Loading plugin: CheckHelpers
D core Loading plugin: CheckNSCP
D check_nscp Crash folder is: C:\Program Files\NSClient++
D core Loading plugin: CheckSystem
D core Loading plugin: NRPEServer
D nrpe Allowed hosts definition: 127.0.0.1(255.255.255.255), 172.16.5.78(255.255.255.255), ::1(ffff:ffff:ffff:ffff:ffff:ffff:ff
ff:ffff)
D nrpe Binding to: [::]:5666(ipv6)
D nrpe Attempting to bind to: [::]:5666(ipv6)
D nrpe Binding to: 0.0.0.0:5666(ipv4), reopen: true, reuse: true
D nrpe Attempting to bind to: 0.0.0.0:5666(ipv4)
D core Loading plugin: NSClientServer
D check_nt Allowed hosts definition: 127.0.0.1(255.255.255.255), 172.16.5.78(255.255.255.255), ::1(ffff:ffff:ffff:ffff:ffff:ffff:ff
ff:ffff)
D check_nt Binding to: [::]:12489(ipv6)
D check_nt Attempting to bind to: [::]:12489(ipv6)
D check_nt Binding to: 0.0.0.0:12489(ipv4), reopen: true, reuse: true
D check_nt Attempting to bind to: 0.0.0.0:12489(ipv4)
D core NSClient++ - 0.4.4.23 2016-04-05 Started!
D core C:\Program Files\NSClient++/modules\CommandClient.dll.dll
D core adding C:\Program Files\NSClient++/modules\CommandClient.dll
D core Loading plugin: CommandClient.dll...
D cli Enter command to execute, help for help or exit to exit...
checknetworkerjob
D ext-script Command line: scripts\Check_Networker_Job.bat EVS01CRS01
L cli UNKNOWN: The command (checknetworkerjob) returned an invalid return code: 255
Reason: Please use [code][/code] tags around long output
What is the output if you run the command directly on the Windows server:
Also, you may need to change the nsclient.ini line:
to:
checknetworkerjob=scripts\\Check_Networker_Job.bat EVS01CRS01
or as @scottwilkerson mentioned:
checknetworkerjob=c:\full\path\to\script\Check_Networker_Job.cmd EVS01CRS01
to:
biswajit.banerjee
We have checked by both command as you suggested. But getting same output.
And
checknetworkerjob=C:\Program Files\NSClient++\scripts\Check_Networker_Job.bat EVS01CRS01
Please suggest how we can resolve this error.
And
Open a command line on the Windows server and navigate to the location of the script:
cd C:\Program Files\NSClient++\scripts\
run:
and provide the output.
run:
