Hello
Can we monitor the hardware firewall by nagios core Version. If yes then please share the steps. thanks in advance.
Regards
Monitor hardware firewall by Nagios core
Re: Monitor hardware firewall by Nagios core
Yes but the possibilities vary based on your firewall.
Here some documentation
https://assets.nagios.com/downloads/nag ... uters.html
Additional plugins are available here
https://exchange.nagios.org/
It is same configuration as we set configuration for the switch? I want to see only it is going to UP or DOWN.
Regards
Regards
If I read your question right, you can use the same plugin to monitor the status of an interface for both a firewall and a switch.
All you need to to is to setup the SNMP community string, version and select the interface number and it should work for either device.
