Monitor IIS Application Pool with Nagios (problem)
Ulfandu
Post by Ulfandu »
Hello.
I'm trying to monitor some IIS Application Pools that one of our server has. I used this guide but for some reason it is not working: https://outsideit.net/monitoring-iis-application-pools/:
Here is the input for the command Get-IISAppPool on the Windows Server I need to monitor:
Here is the nagios core's nsclient.ini:
# If you want to fill this file with all available options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
# IIS application poolin monitoring:
check_ms_iis_application_pool=cmd /c echo scripts/powershell/check_ms_iis_application_pool.ps1 $ARG1$; exit $LastExitCode | powershell.exe /noprofile -command -
; in flight - TODO
[/settings/default]
; Undocumented key
password = 1234
; Undocumented key
allowed hosts = 192.168.1.10
; in flight - TODO
[/settings/NRPE/server]
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
; in flight - TODO
[/modules]
; Undocumented key
CheckExternalScripts = enabled
; Undocumented key
CheckHelpers = enabled
; Undocumented key
CheckNSCP = enabled
; Undocumented key
CheckDisk = enabled
; Undocumented key
WEBServer = enabled
; Undocumented key
CheckSystem = enabled
; Undocumented key
NSClientServer = enabled
; Undocumented key
CheckEventLog = enabled
; Undocumented key
NSCAClient = enabled
; Undocumented key
NRPEServer = enabled
Here is the command I defined in nagios' commands.cfg-file:
# 'check_ms_iis_application_pool' command definition
        command_name    check_ms_iis_application_pool
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -t 60 -c check_ms_iis_application_pool "$ARG1$"
And here is the service for the host server in the file windows.cfg:
       host_name               IIS-Server
       service_description     XXXPool
       check_command check_nrpe!check_ms_iis_application_pool -a '-A <IIS-Server>'
I would be very thankful if someone could help me with this problem. I tried Googling this problem, but couldn't find any information on how to specifically define the service.
I suspected that there might be something wrong with windows.cfg, so I tried editing the line:
check_command           check_nrpe!check_ms_iis_application_pool! -a '-A <XXXPool>'
check_command           check_nrpe!check_ms_iis_application_pool! -a '-A XXXPool'
check_command           check_nrpe!check_ms_iis_application_pool! -a -A XXXPool
check_ms_iis_application_pool not working.png (4.78 KiB) Viewed 4978 times
Re: Monitor IIS Application Pool with Nagios (problem)
Post by mcapra »
First off, thanks for providing *all* of the dang information required to start troubleshooting this problem. That's top-notch :)
Check out this KB article:
https://support.nagios.com/kb/article.php?id=528
I believe you just need to move your check_ms_iis_application_pool command definition to the [/settings/external scripts/scripts] section of your nsclient.ini file. Like so:
Give that a try, restart the NSClient++ service, and see if you get the desired effect. If it's still giving you bad output when executed from the Nagios Core machine, please share the output. It would also be useful to know your NSClient++ version, which can be found like so:
/path/to/check_nrpe -H <your windows host>
Or by checking the nscp executable's properties on the remote Windows machine.
kyang
Post by kyang »
Thanks for the help @mcapra!
Ulfandu, let us know if you have any more questions. Otherwise, please proceed with mcapra's suggestions!
