I tried to apply configuration and all I get is "Waiting for configuration verification........."
I go into configuration snapshot to see if I can find the error, but it does not even register that I am trying to apply configuration as the last known good was from 4/29/2018.
Out of desperation, I deactivate all host, all services, all hostgroups and all servicegroups (this is a lab environment), it still won't apply configuration. Does anyone come across this issue before?
Unable to apply configuration
npolovenko
- Support Tech
Re: Unable to apply configuration
Hello, @huanglil.
Please sign in to the console as the nagios user:
Then go to the scripts folder:
And run:
Please show us the output when you run this script.
su - nagiosCode: Select all
/usr/local/nagiosxi/scripts/Code: Select all
./reconfigure_nagios.shAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
