I try to monitor an Exchange Windows 2012 Server.
But I constantly get a socket timeout after 10s.
I've followed this support page: https://support.nagios.com/kb/article/n ... s-617.html
The nagios XI server is 192.168.0.187 & the Exchange server to monitor is 192.168.0.40
Here is my nrpe.conf
log_facility=daemon
debug=0
pid_file=/usr/local/nagios/var/nrpe.pid
server_port=5666
#server_address=127.0.0.1
#listen_queue_size=5
nrpe_user=nagios
nrpe_group=nagios
allowed_hosts=127.0.0.1,::1,192.168.0.187
dont_blame_nrpe=1
command_timeout=300
connection_timeout=300
#allow_weak_random_seed=1
#ssl_version=SSLv2+
#ssl_use_adh=1
#ssl_cipher_list=ALL:!MD5:@STRENGTH
#ssl_cipher_list=ALL:!MD5:@STRENGTH:@SECLEVEL=0
#ssl_cipher_list=ALL:!aNULL:!eNULL:!SSLv2:!LOW:!EXP:!RC4:!MD5:@STRENGTH
#ssl_cacert_file=/etc/ssl/servercerts/ca-cert.pem
#ssl_cert_file=/etc/ssl/servercerts/nagios-cert.pem
#ssl_privatekey_file=/etc/ssl/servercerts/nagios-key.pem
#ssl_client_certs=0
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$\tLONGSERVICEOUTPUT::$LONGSERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$\tLONGHOSTOUTPUT::$LONGHOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=1
auto_rescheduling_interval=30
auto_rescheduling_window=45
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=300
execute_host_checks=1
execute_service_checks=1
high_host_flap_threshold=20.0
host_check_timeout=300
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=60
service_interleave_factor=s
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/tmp
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0Code: Select all
2018-06-18 10:38:02: error:c:\source\nscp\modules\NRPEServer\NRPEServer.cpp:132: Certificate not found: C:\Program Files\NSClient++/security/certificate.pem (generating a default certificate)
2018-06-18 10:38:02: error:c:\source\nscp\modules\NRPEServer\NRPEServer.cpp:132: CA not found: C:\Program Files\NSClient++/security/ca.pem (generating a default CA)
2018-06-18 10:39:54: error:c:\source\nscp\include\nrpe/server/protocol.hpp:80: Rejected connection from: 192.168.0.40
2018-06-18 10:40:42: error:c:\source\nscp\include\nrpe/server/protocol.hpp:80: Rejected connection from: 192.168.0.40
2018-06-18 10:40:43: error:c:\source\nscp\include\nrpe/server/protocol.hpp:80: Rejected connection from: 192.168.0.40
2018-06-18 10:43:37: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: no certificate returned: 178
2018-06-18 10:43:48: error:c:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2018-06-18 10:43:48: error:c:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2018-06-18 10:45:27: error:c:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2018-06-18 10:45:27: error:c:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2018-06-18 10:47:43: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: short read: 219
2018-06-18 10:47:52: error:c:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2018-06-18 10:47:52: error:c:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2018-06-18 10:48:10: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 10:48:26: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 10:52:23: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 11:02:46: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 11:03:04: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 11:11:50: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 11:12:03: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 11:12:32: error:c:\source\nscp\include\socket/connection.hpp:240: Seems we cant agree on SSL: no shared cipher
2018-06-18 11:12:32: error:c:\source\nscp\include\socket/connection.hpp:241: PLease review the legacy as well as ssl options in settings.
2018-06-18 11:12:40: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 11:12:41: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 11:33:08: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 11:37:57: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert handshake failure: 1040
2018-06-18 11:40:50: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 11:55:51: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 12:05:28: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 12:05:57: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: sslv3 alert unexpected message: 1010
2018-06-18 12:06:36: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 12:11:27: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252
2018-06-18 15:09:08: error:c:\source\nscp\include\socket/connection.hpp:243: Failed to establish secure connection: unknown protocol: 252Code: Select all
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; Undocumented key
password = exchmonitor
; Undocumented key
allowed hosts = 127.0.0.1,::1,192.168.0.187,192.168.0.40
[/settings/NRPE/server]
; Undocumented key
ssl options = no-sslv2,no-sslv3
; Undocumented key
verify mode = peer-cert
; Undocumented key
insecure = true
[/modules]
; Undocumented key
CheckExternalScripts = 1
; Undocumented key
CheckHelpers = 1
; Undocumented key
CheckEventLog = 1
; Undocumented key
CheckNSCP = 1
; Undocumented key
CheckDisk = 1
; Undocumented key
CheckSystem = 1
; Undocumented key
NRPEServer = 1
Thank you for your help.
