Nagios LMS - Client Script Accidently Run on Server Itself
jslawrenc
Post by jslawrenc »
It appears the client agent script was mistakenly setup on the server itself (terminal sessions mixed up). It's now sending logs to itself as a log source. Is there an easy way to undo this? Would I just create a localhost config filter to block logs looping to itself?
Re: Nagios LMS - Client Script Accidently Run on Server Itse
Post by mcapra »
You could disable the local rsyslog service, or remove the nagioslogserver config file located in /etc/rsyslog.d and restart the rsyslog service.
mcapra wrote:You could disable the local rsyslog service, or remove the nagioslogserver config file located in /etc/rsyslog.d and restart the rsyslog service.
Yes this should do it. For the record, this is done by default on install.
jslawrenc
Post by jslawrenc »
Thank you guys. I'm just getting familiar with Nagios LMS. Really appreciate the advice here.
jslawrenc wrote:Thank you guys. I'm just getting familiar with Nagios LMS. Really appreciate the advice here.
No problem.
Locking thread
