we receive every week for 1 or 2 times a Database Error after login and don't see any information for hosts and services.
After using the repair_databases.sh it works some days but the error happen again.
What happen ?
best regards
thomas
Database Error
Database Error
Re: Database Error
The most common reason for the database to require repair is if there is a power failure, and this would include hitting the STOP button in a VM environment vs. running the shutdown command from the CLI.
