I'm not able to login to my cluster; when I try to login to either server it times out.
On one of the servers, the login times out and returns "The username specified does not exist." The login uses LDAP.
I'm running version 2.0.3
I've restarted elasticsearch, logstash, and httpd multiple times on both servers
There's plenty of disk space
I've increased the memory_limit in /etc/php.ini to 512MB
Running
curl -XGET 'http://localhost:9200/_cat/indices?pretty'I've run the profile.sh script; shall I send in the output?
Michael
