Our network support engineer would like to know if you have a newer .OVA file for deployment on VMware. He was not able to apply the "VMware Tools and Compatibility Upgrades" on the current VM.
Thanks.
Steve
Unable To Apply VMware Tools and Compatibility Upgrades
Re: Unable To Apply VMware Tools and Compatibility Upgrades
VMWare tools are not pre-installed on our VM's.
Your admin would have to install the tools manually if they are desired.
We figured it out -- thanks.
Steve
Steve
Excellent.vornado wrote:We figured it out -- thanks.
Steve
Locking
