Hello everyone,
I am using the plugin for oracle from nagios XI and in a particular service I have problems.
The service with problems is tablespace-can-allocate-next, the rest works without problems.
The error is as follows:
[root@nagiosXI]# /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect '192.168.2.10:1521/DDBB_SRV' --username 'nagios' --password 'oradbmon' --mode tablespace-can-allocate-next --warning 20 --critical 30
UNKNOWN - check_oracle_health timed out after 60 seconds
The nagios log shows the following:
Jun 20 17:53:11 nagiosXI nagios: SERVICE ALERT: bdrac1;Tablespace SYSTEM Can Allocate Next;UNKNOWN;HARD;5;UNKNOWN - check_oracle_health timed out after 60 seconds
Thank you
Re: UNKNOWN - check_oracle_health timed out after 60 seconds
Have you attempted to increase the timeout?
I have seen some info on other sites that this mode can take a very long time
/usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client64/lib ORACLE_HOME=/usr/lib/oracle/11.2/client64 /usr/local/nagios/libexec/check_oracle_health --connect '192.168.2.10:1521/DDBB_SRV' --username 'nagios' --password 'oradbmon' --mode tablespace-can-allocate-next --warning 20 --critical 30 --timeout 120
