I have three different groups of equiments eg Group 1, Group 2 and Group 3. Using ONLY ONE one instance and disk partitioning, I need to know how I can achieve/direct Group 1 logs to partion 1, Group 2 to partion 2 and Group 3 to partition 3. Thanks.
Recieve Logs in the different partions on the same server
Re: Recieve Logs in the different partions on the same serve
Do you mean store the data in different partitions on disk?
If so, this is not possible.
Yes, I meant store the logs in different partitions, as chosen by myself. eg Logs of Group A equipments in partition 1, logs of Group B equipments in partition 2....... Oh so its not possible?
Alright. Thanks for your quick response.
