Dashlet scrollbars not appearing
This support forum board is for questions relating to Nagios Fusion.
nortonhealthcare
Post by nortonhealthcare »
Hello all,
In our use of Nagios Fusion version 4.1.4, when I add dashlets to dashboards, no verticle or horizontal scrollbars appear. The dashlets can only display what initially appears in the dashlet. For instance, if "Open Host Problems" has more rows than can fit in the size of that servlet window, you cannot scroll to see the remaining rows. Is this normal behavior?
Also, can anybody tell me what the "Z Index" does?
Regards,
Ben Kopacz
Re: Dashlet scrollbars not appearing
Yes you may need to resize the dashlets.
Because dashlets can overlap each other the z-index sets which will be on top or bottom based on using different values in the z-index field.
nortonhealthcare
Thank you for the quick reply! Are there any plans to add that scrollbar functionality in the future? Also, is there any way to get the "Birdseye View" in Fusion like it is in XI?
There will likely never be scrollbars in a standard dashlet, as they are just small html fragments
As for the Birdseye view, There is no current plans but I can enter a feature request if you like, no promises it will get added or timing of when if it does.
nortonhealthcare
Yes, if you could put in a feature request for a birds eye view for Fusion I would greatly appreciate it!
Requested.
