Is there documentation anywhere on where and how to install the VM image I downloaded for NAGIOS XI. I'm not really a big VMware guy, but I'm wanting to install the image instead of building a VM from scratch. From what I see, from the ESX server I need to "import virtual appliance". Do I copy it somewhere specifically first? Do I point to the current location and it copies over by itself?
Thanks in advance for help on these dumb questions.
NAGIOS XI Image Installation
desmondlewissmith
Plan B is to make Plan A work.
desmondlewissmith
Re: NAGIOS XI Image Installation
I figured it out, I had to use the VMware vCenter Converter Standalone Client to import the VM.
Glad to see you got it sorted out.
For completeness the installation options section of the Administrative guide has a section on this
http://assets.nagios.com/downloads/nagi ... ionoptions
