[solved] Create pattern to logs
rodrigoaguilar
Post by rodrigoaguilar »
<184>BSR 64000(tm):[05/12-04:45:13.98- 07:tRDNts6586]-M-CLI-TRACKER[peter.parker]: command
Hello everyone, I don't know how to create a pattern for the previous records, I need to identify the user, in this case it is peter.parker
:D
Last edited by rodrigoaguilar on Mon Jun 25, 2018 8:21 am, edited 1 time in total.
Re: Create pattern to logs
Here is a doc outlining creating grok patterns starting on page 2
https://assets.nagios.com/downloads/nag ... ilters.pdf
Here is a good place to test your patterns
https://grokdebug.herokuapp.com/
rodrigoaguilar
tnks man
The result
\<%{NUMBER:ID}\>%{WORD:model} %{NUMBER:model}\(.*\):\[(?<timestamp>%{MONTHNUM}/%{MONTHDAY}-%{TIME}).*- .*:.*\]-M-CLI-TRACKER\[%{USERNAME}\]:%{GREEDYDATA:message}
  "ID": [
      "184"
  "BASE10NUM": [
      "184",
      "64000"
  "model": [
      "BSR"
      "64000"
  "timestamp": [
      "05/12-04:45:13.98"
  "MONTHNUM": [
      "05"
  "MONTHDAY": [
      "12"
  "TIME": [
      "04:45:13.98"
  "HOUR": [
      "04"
  "MINUTE": [
      "45"
  "SECOND": [
      "13.98"
  "USERNAME": [
      "peter.parker"
  "message": [
      " show run"
Reason: Please use [code][/code] tags around long output
Excellent!
