Trying to import contact from AD/LDAP
Added the server successfully.
But every time when try to login to start the import it gives the the Authentication Error.
- When I tried by setting the encryption level to NONE, it gave the following error in both cases "Active Directory and LDAP"
"Unable to authenticate: Could not connect to the LDAP server selected"
- When I use the LDAP server with SSL encryption, it gives the following error : "Unable to authenticate: TLS error -5961:TCP connection reset by peer"
- When I use the AD server with SSL encryption, it gives the following error : "Unable to authenticate: Could not connect to the LDAP server selected"
- I even tried importing the certificate but the same issue.
The NagiosXI server and the AD server are pinging but only with the IP.
Unable to ping the AD server from NagiosXI server by using the host name.
Unable to run the telnet from NagiosXI server to the AD server.
Kindly let me know what shall be done further?
Authentication issue on Importing contacts from AD
linearstack
Re: Authentication issue on Importing contacts from AD
The failure of telnet test from XI to the AD server would indicate something blocking the port(firewall usually) or the port isn't up. Can you provide a screenshot of the settings that you're using on XI to connect to AD as well as the output of "netstat -na" on the DC? For now, I would try testing with the "none" encryption option unless it is a requirement to connect to the DC.
linearstack
Following is the outcome of the "netstat -na" on the DC with the IP address 192.168.202.77 :-
PS C:\Users\ls.admin> netstat -na
Active Connections
Proto Local Address Foreign Address State
TCP 0.0.0.0:80 0.0.0.0:0 LISTENING
TCP 0.0.0.0:88 0.0.0.0:0 LISTENING
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:389 0.0.0.0:0 LISTENING
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING
TCP 0.0.0.0:464 0.0.0.0:0 LISTENING
TCP 0.0.0.0:593 0.0.0.0:0 LISTENING
TCP 0.0.0.0:636 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3268 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3269 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3389 0.0.0.0:0 LISTENING
TCP 0.0.0.0:5985 0.0.0.0:0 LISTENING
TCP 0.0.0.0:9389 0.0.0.0:0 LISTENING
TCP 0.0.0.0:47001 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49157 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49158 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49159 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49166 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49175 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49199 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49208 0.0.0.0:0 LISTENING
TCP 127.0.0.1:53 0.0.0.0:0 LISTENING
TCP 127.0.0.1:389 127.0.0.1:49161 ESTABLISHED
TCP 127.0.0.1:389 127.0.0.1:49163 ESTABLISHED
TCP 127.0.0.1:389 127.0.0.1:59059 ESTABLISHED
TCP 127.0.0.1:49161 127.0.0.1:389 ESTABLISHED
TCP 127.0.0.1:49163 127.0.0.1:389 ESTABLISHED
TCP 127.0.0.1:59059 127.0.0.1:389 ESTABLISHED
TCP 192.168.202.77:53 0.0.0.0:0 LISTENING
TCP 192.168.202.77:139 0.0.0.0:0 LISTENING
TCP 192.168.202.77:389 192.168.202.77:59073 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.77:59080 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:50724 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:50791 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:50813 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:50815 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:50816 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51227 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51232 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51234 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51235 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51236 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51237 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51238 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51244 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51245 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51257 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51258 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51259 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51260 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51265 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51275 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51290 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51291 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51292 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51293 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51294 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51295 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51296 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51297 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51301 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51302 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51303 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51304 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51305 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51310 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51318 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51327 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51329 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51346 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51349 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51350 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51351 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51352 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51353 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51354 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51355 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51357 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51358 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51359 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51360 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51362 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51363 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51364 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51378 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51505 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51534 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51765 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:51932 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52021 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52026 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52040 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52057 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52306 ESTABLISHED
TCP 192.168.202.77:389 192.168.202.78:52453 ESTABLISHED
TCP 192.168.202.77:445 192.168.202.78:55213 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:50812 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:50980 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51226 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51242 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51243 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51254 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51271 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51285 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51289 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51317 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51323 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51324 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51432 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51440 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51454 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51460 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:51580 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:54228 ESTABLISHED
TCP 192.168.202.77:3268 192.168.202.78:54631 ESTABLISHED
TCP 192.168.202.77:3389 192.168.202.50:55816 ESTABLISHED
TCP 192.168.202.77:49155 192.168.202.78:55066 TIME_WAIT
TCP 192.168.202.77:49155 192.168.202.78:55067 TIME_WAIT
TCP 192.168.202.77:49155 192.168.202.78:55070 ESTABLISHED
TCP 192.168.202.77:49155 192.168.202.78:55146 TIME_WAIT
TCP 192.168.202.77:59073 192.168.202.77:389 ESTABLISHED
TCP 192.168.202.77:59080 192.168.202.77:389 ESTABLISHED
TCP [::]:80 [::]:0 LISTENING
TCP [::]:88 [::]:0 LISTENING
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:464 [::]:0 LISTENING
TCP [::]:593 [::]:0 LISTENING
TCP [::]:3389 [::]:0 LISTENING
TCP [::]:5985 [::]:0 LISTENING
TCP [::]:9389 [::]:0 LISTENING
TCP [::]:47001 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49157 [::]:0 LISTENING
TCP [::]:49158 [::]:0 LISTENING
TCP [::]:49159 [::]:0 LISTENING
TCP [::]:49166 [::]:0 LISTENING
TCP [::]:49175 [::]:0 LISTENING
TCP [::]:49199 [::]:0 LISTENING
TCP [::]:49208 [::]:0 LISTENING
TCP [::1]:53 [::]:0 LISTENING
TCP [::1]:49155 [::1]:49180 ESTABLISHED
TCP [::1]:49155 [::1]:49203 ESTABLISHED
TCP [::1]:49155 [::1]:49312 ESTABLISHED
TCP [::1]:49180 [::1]:49155 ESTABLISHED
TCP [::1]:49203 [::1]:49155 ESTABLISHED
TCP [::1]:49312 [::1]:49155 ESTABLISHED
UDP 0.0.0.0:123 *:*
UDP 0.0.0.0:389 *:*
UDP 0.0.0.0:3389 *:*
UDP 0.0.0.0:5355 *:*
UDP 0.0.0.0:51921 *:*
UDP 0.0.0.0:51922 *:*
UDP 0.0.0.0:51923 *:*
UDP 0.0.0.0:51924 *:*
UDP 0.0.0.0:51925 *:*
UDP 0.0.0.0:51926 *:*
UDP 0.0.0.0:51927 *:*
UDP 0.0.0.0:51928 *:*
UDP 0.0.0.0:51929 *:*
UDP 0.0.0.0:51930 *:*
UDP 0.0.0.0:51931 *:*
UDP 0.0.0.0:51932 *:*
UDP 0.0.0.0:51933 *:*
UDP 0.0.0.0:51934 *:*
UDP 0.0.0.0:51935 *:*
UDP 0.0.0.0:51936 *:*
UDP 0.0.0.0:51937 *:*
UDP 0.0.0.0:51938 *:*
UDP 0.0.0.0:51939 *:*
UDP 0.0.0.0:51940 *:*
UDP 0.0.0.0:51941 *:*
UDP 0.0.0.0:51942 *:*
UDP 0.0.0.0:51943 *:*
UDP 0.0.0.0:51944 *:*
UDP 0.0.0.0:51945 *:*
UDP 0.0.0.0:51946 *:*
UDP 0.0.0.0:51947 *:*
UDP 0.0.0.0:51948 *:*
UDP 0.0.0.0:51949 *:*
UDP 0.0.0.0:51950 *:*
UDP 0.0.0.0:51951 *:*
UDP 0.0.0.0:51952 *:*
UDP 0.0.0.0:51953 *:*
UDP 0.0.0.0:51954 *:*
UDP 0.0.0.0:51955 *:*
UDP 0.0.0.0:51956 *:*
UDP 0.0.0.0:51957 *:*
UDP 0.0.0.0:51958 *:*
UDP 0.0.0.0:51959 *:*
UDP 0.0.0.0:51960 *:*
UDP 0.0.0.0:51961 *:*
UDP 0.0.0.0:51962 *:*
UDP 0.0.0.0:51963 *:*
UDP 0.0.0.0:51964 *:*
UDP 0.0.0.0:51965 *:*
UDP 0.0.0.0:51966 *:*
UDP 0.0.0.0:51967 *:*
UDP 0.0.0.0:51968 *:*
UDP 0.0.0.0:51969 *:*
UDP 0.0.0.0:51970 *:*
UDP 0.0.0.0:51971 *:*
UDP 0.0.0.0:51972 *:*
UDP 0.0.0.0:51973 *:*
UDP 0.0.0.0:51974 *:*
UDP 0.0.0.0:51975 *:*
UDP 0.0.0.0:51976 *:*
UDP 0.0.0.0:51977 *:*
UDP 0.0.0.0:51978 *:*
UDP 0.0.0.0:51979 *:*
UDP 0.0.0.0:51980 *:*
UDP 0.0.0.0:51981 *:*
UDP 0.0.0.0:51982 *:*
UDP 0.0.0.0:51983 *:*
UDP 0.0.0.0:51984 *:*
UDP 0.0.0.0:51985 *:*
UDP 0.0.0.0:51986 *:*
UDP 0.0.0.0:51987 *:*
UDP 0.0.0.0:51988 *:*
UDP 0.0.0.0:51989 *:*
UDP 0.0.0.0:51990 *:*
UDP 0.0.0.0:51991 *:*
UDP 0.0.0.0:51992 *:*
UDP 0.0.0.0:51993 *:*
UDP 0.0.0.0:51994 *:*
UDP 0.0.0.0:51995 *:*
UDP 0.0.0.0:51996 *:*
UDP 0.0.0.0:51997 *:*
UDP 0.0.0.0:51998 *:*
UDP 0.0.0.0:51999 *:*
UDP 0.0.0.0:52000 *:*
UDP 0.0.0.0:52001 *:*
UDP 0.0.0.0:52002 *:*
UDP 0.0.0.0:52003 *:*
UDP 0.0.0.0:52004 *:*
UDP 0.0.0.0:52005 *:*
UDP 0.0.0.0:52006 *:*
UDP 0.0.0.0:52007 *:*
UDP 0.0.0.0:52008 *:*
UDP 0.0.0.0:52009 *:*
UDP 0.0.0.0:52010 *:*
UDP 0.0.0.0:52011 *:*
UDP 0.0.0.0:52012 *:*
UDP 0.0.0.0:52013 *:*
UDP 0.0.0.0:52014 *:*
UDP 0.0.0.0:52015 *:*
UDP 0.0.0.0:52016 *:*
UDP 0.0.0.0:52017 *:*
UDP 0.0.0.0:52018 *:*
UDP 0.0.0.0:52019 *:*
UDP 0.0.0.0:52020 *:*
UDP 0.0.0.0:52021 *:*
UDP 0.0.0.0:52022 *:*
UDP 0.0.0.0:52023 *:*
UDP 0.0.0.0:52024 *:*
UDP 0.0.0.0:52025 *:*
UDP 0.0.0.0:52026 *:*
UDP 0.0.0.0:52027 *:*
UDP 0.0.0.0:52028 *:*
UDP 0.0.0.0:52029 *:*
UDP 0.0.0.0:52030 *:*
UDP 0.0.0.0:52031 *:*
UDP 0.0.0.0:52032 *:*
UDP 0.0.0.0:52033 *:*
UDP 0.0.0.0:52034 *:*
UDP 0.0.0.0:52035 *:*
UDP 0.0.0.0:52036 *:*
UDP 0.0.0.0:52037 *:*
UDP 0.0.0.0:52038 *:*
UDP 0.0.0.0:52039 *:*
UDP 0.0.0.0:52040 *:*
UDP 0.0.0.0:52041 *:*
UDP 0.0.0.0:52042 *:*
UDP 0.0.0.0:52043 *:*
UDP 0.0.0.0:52044 *:*
UDP 0.0.0.0:52045 *:*
UDP 0.0.0.0:52046 *:*
UDP 0.0.0.0:52047 *:*
UDP 0.0.0.0:52048 *:*
UDP 0.0.0.0:52049 *:*
UDP 0.0.0.0:52050 *:*
UDP 0.0.0.0:52051 *:*
UDP 0.0.0.0:52052 *:*
UDP 0.0.0.0:52053 *:*
UDP 0.0.0.0:52054 *:*
UDP 0.0.0.0:52055 *:*
UDP 0.0.0.0:52056 *:*
UDP 0.0.0.0:52057 *:*
UDP 0.0.0.0:52058 *:*
UDP 0.0.0.0:52059 *:*
UDP 0.0.0.0:52060 *:*
UDP 0.0.0.0:52061 *:*
UDP 0.0.0.0:52062 *:*
UDP 0.0.0.0:52063 *:*
UDP 0.0.0.0:52064 *:*
UDP 0.0.0.0:52065 *:*
UDP 0.0.0.0:52066 *:*
UDP 0.0.0.0:52067 *:*
UDP 0.0.0.0:52068 *:*
UDP 0.0.0.0:52069 *:*
UDP 0.0.0.0:52070 *:*
UDP 0.0.0.0:52071 *:*
UDP 0.0.0.0:52072 *:*
UDP 0.0.0.0:52073 *:*
UDP 0.0.0.0:52074 *:*
UDP 0.0.0.0:52075 *:*
UDP 0.0.0.0:52076 *:*
UDP 0.0.0.0:52077 *:*
UDP 0.0.0.0:52078 *:*
UDP 0.0.0.0:52079 *:*
UDP 0.0.0.0:52080 *:*
UDP 0.0.0.0:52081 *:*
UDP 0.0.0.0:52082 *:*
UDP 0.0.0.0:52083 *:*
UDP 0.0.0.0:52084 *:*
UDP 0.0.0.0:52085 *:*
UDP 0.0.0.0:52086 *:*
UDP 0.0.0.0:52087 *:*
UDP 0.0.0.0:52088 *:*
UDP 0.0.0.0:52089 *:*
UDP 0.0.0.0:52090 *:*
UDP 0.0.0.0:52091 *:*
UDP 0.0.0.0:52092 *:*
UDP 0.0.0.0:52093 *:*
UDP 0.0.0.0:52094 *:*
UDP 0.0.0.0:52095 *:*
UDP 0.0.0.0:52096 *:*
UDP 0.0.0.0:52097 *:*
UDP 0.0.0.0:52098 *:*
UDP 0.0.0.0:52099 *:*
UDP 0.0.0.0:52100 *:*
UDP 0.0.0.0:52101 *:*
UDP 0.0.0.0:52102 *:*
UDP 0.0.0.0:52103 *:*
UDP 0.0.0.0:52104 *:*
UDP 0.0.0.0:52105 *:*
UDP 0.0.0.0:52106 *:*
UDP 0.0.0.0:52107 *:*
UDP 0.0.0.0:52108 *:*
UDP 0.0.0.0:52109 *:*
UDP 0.0.0.0:52110 *:*
UDP 0.0.0.0:52111 *:*
UDP 0.0.0.0:52112 *:*
UDP 0.0.0.0:52113 *:*
UDP 0.0.0.0:52114 *:*
UDP 0.0.0.0:52115 *:*
UDP 0.0.0.0:52116 *:*
UDP 0.0.0.0:52117 *:*
UDP 0.0.0.0:52118 *:*
UDP 0.0.0.0:52119 *:*
UDP 0.0.0.0:52120 *:*
UDP 0.0.0.0:52121 *:*
UDP 0.0.0.0:52122 *:*
UDP 0.0.0.0:52123 *:*
UDP 0.0.0.0:52124 *:*
UDP 0.0.0.0:52125 *:*
UDP 0.0.0.0:52126 *:*
UDP 0.0.0.0:52127 *:*
UDP 0.0.0.0:52128 *:*
UDP 0.0.0.0:52129 *:*
UDP 0.0.0.0:52130 *:*
UDP 0.0.0.0:52131 *:*
UDP 0.0.0.0:52132 *:*
UDP 0.0.0.0:52133 *:*
UDP 0.0.0.0:52134 *:*
UDP 0.0.0.0:52135 *:*
UDP 0.0.0.0:52136 *:*
UDP 0.0.0.0:52137 *:*
UDP 0.0.0.0:52138 *:*
UDP 0.0.0.0:52139 *:*
UDP 0.0.0.0:52140 *:*
UDP 0.0.0.0:52141 *:*
UDP 0.0.0.0:52142 *:*
UDP 0.0.0.0:52143 *:*
UDP 0.0.0.0:52144 *:*
UDP 0.0.0.0:52145 *:*
UDP 0.0.0.0:52146 *:*
UDP 0.0.0.0:52147 *:*
UDP 0.0.0.0:52148 *:*
UDP 0.0.0.0:52149 *:*
UDP 0.0.0.0:52150 *:*
UDP 0.0.0.0:52151 *:*
UDP 0.0.0.0:52152 *:*
UDP 0.0.0.0:52153 *:*
UDP 0.0.0.0:52154 *:*
UDP 0.0.0.0:52155 *:*
UDP 0.0.0.0:52156 *:*
UDP 0.0.0.0:52157 *:*
UDP 0.0.0.0:52158 *:*
UDP 0.0.0.0:52159 *:*
UDP 0.0.0.0:52160 *:*
UDP 0.0.0.0:52161 *:*
UDP 0.0.0.0:52162 *:*
UDP 0.0.0.0:52163 *:*
UDP 0.0.0.0:52164 *:*
UDP 0.0.0.0:52165 *:*
UDP 0.0.0.0:52166 *:*
UDP 0.0.0.0:52167 *:*
UDP 0.0.0.0:52168 *:*
UDP 0.0.0.0:52169 *:*
UDP 0.0.0.0:52170 *:*
UDP 0.0.0.0:52171 *:*
UDP 0.0.0.0:52172 *:*
UDP 0.0.0.0:52173 *:*
UDP 0.0.0.0:52174 *:*
UDP 0.0.0.0:52175 *:*
UDP 0.0.0.0:52176 *:*
UDP 0.0.0.0:52177 *:*
UDP 0.0.0.0:52178 *:*
UDP 0.0.0.0:52179 *:*
UDP 0.0.0.0:52180 *:*
UDP 0.0.0.0:52181 *:*
UDP 0.0.0.0:52182 *:*
UDP 0.0.0.0:52183 *:*
UDP 0.0.0.0:52184 *:*
UDP 0.0.0.0:52185 *:*
UDP 0.0.0.0:52186 *:*
UDP 0.0.0.0:52187 *:*
UDP 0.0.0.0:52188 *:*
UDP 0.0.0.0:52189 *:*
UDP 0.0.0.0:52190 *:*
UDP 0.0.0.0:52191 *:*
UDP 0.0.0.0:52192 *:*
UDP 0.0.0.0:52193 *:*
UDP 0.0.0.0:52194 *:*
UDP 0.0.0.0:52195 *:*
UDP 0.0.0.0:52196 *:*
UDP 0.0.0.0:52197 *:*
UDP 0.0.0.0:52198 *:*
UDP 0.0.0.0:52199 *:*
UDP 0.0.0.0:52200 *:*
UDP 0.0.0.0:52201 *:*
UDP 0.0.0.0:52202 *:*
UDP 0.0.0.0:52203 *:*
UDP 0.0.0.0:52204 *:*
UDP 0.0.0.0:52205 *:*
UDP 0.0.0.0:52206 *:*
UDP 0.0.0.0:52207 *:*
UDP 0.0.0.0:52208 *:*
UDP 0.0.0.0:52209 *:*
UDP 0.0.0.0:52210 *:*
UDP 0.0.0.0:52211 *:*
UDP 0.0.0.0:52212 *:*
UDP 0.0.0.0:52213 *:*
UDP 0.0.0.0:52214 *:*
UDP 0.0.0.0:52215 *:*
UDP 0.0.0.0:52216 *:*
UDP 0.0.0.0:52217 *:*
UDP 0.0.0.0:52218 *:*
UDP 0.0.0.0:52219 *:*
UDP 0.0.0.0:52220 *:*
UDP 0.0.0.0:52221 *:*
UDP 0.0.0.0:52222 *:*
UDP 0.0.0.0:52223 *:*
UDP 0.0.0.0:52224 *:*
UDP 0.0.0.0:52225 *:*
UDP 0.0.0.0:52226 *:*
UDP 0.0.0.0:52227 *:*
UDP 0.0.0.0:52228 *:*
UDP 0.0.0.0:52229 *:*
UDP 0.0.0.0:52230 *:*
UDP 0.0.0.0:52231 *:*
UDP 0.0.0.0:52232 *:*
UDP 0.0.0.0:52233 *:*
UDP 0.0.0.0:52234 *:*
UDP 0.0.0.0:52235 *:*
UDP 0.0.0.0:52236 *:*
UDP 0.0.0.0:52237 *:*
UDP 0.0.0.0:52238 *:*
UDP 0.0.0.0:52239 *:*
UDP 0.0.0.0:52240 *:*
UDP 0.0.0.0:52241 *:*
UDP 0.0.0.0:52242 *:*
UDP 0.0.0.0:52243 *:*
UDP 0.0.0.0:52244 *:*
UDP 0.0.0.0:52245 *:*
UDP 0.0.0.0:52246 *:*
UDP 0.0.0.0:52247 *:*
UDP 0.0.0.0:52248 *:*
UDP 0.0.0.0:52249 *:*
UDP 0.0.0.0:52250 *:*
UDP 0.0.0.0:52251 *:*
UDP 0.0.0.0:52252 *:*
UDP 0.0.0.0:52253 *:*
UDP 0.0.0.0:52254 *:*
UDP 0.0.0.0:52255 *:*
UDP 0.0.0.0:52256 *:*
UDP 0.0.0.0:52257 *:*
UDP 0.0.0.0:52258 *:*
UDP 0.0.0.0:52259 *:*
UDP 0.0.0.0:52260 *:*
UDP 0.0.0.0:52261 *:*
UDP 0.0.0.0:52262 *:*
UDP 0.0.0.0:52263 *:*
UDP 0.0.0.0:52264 *:*
UDP 0.0.0.0:52265 *:*
UDP 0.0.0.0:52266 *:*
UDP 0.0.0.0:52267 *:*
UDP 0.0.0.0:52268 *:*
UDP 0.0.0.0:52269 *:*
UDP 0.0.0.0:52270 *:*
UDP 0.0.0.0:52271 *:*
UDP 0.0.0.0:52272 *:*
UDP 0.0.0.0:52273 *:*
UDP 0.0.0.0:52274 *:*
UDP 0.0.0.0:52275 *:*
UDP 0.0.0.0:52276 *:*
UDP 0.0.0.0:52277 *:*
UDP 0.0.0.0:52278 *:*
UDP 0.0.0.0:52279 *:*
UDP 0.0.0.0:52280 *:*
UDP 0.0.0.0:52281 *:*
UDP 0.0.0.0:52282 *:*
UDP 0.0.0.0:52283 *:*
UDP 0.0.0.0:52284 *:*
UDP 0.0.0.0:52285 *:*
UDP 0.0.0.0:52286 *:*
UDP 0.0.0.0:52287 *:*
UDP 0.0.0.0:52288 *:*
UDP 0.0.0.0:52289 *:*
UDP 0.0.0.0:52290 *:*
UDP 0.0.0.0:52291 *:*
UDP 0.0.0.0:52292 *:*
UDP 0.0.0.0:52293 *:*
UDP 0.0.0.0:52294 *:*
UDP 0.0.0.0:52295 *:*
UDP 0.0.0.0:52296 *:*
UDP 0.0.0.0:52297 *:*
UDP 0.0.0.0:52298 *:*
UDP 0.0.0.0:52299 *:*
UDP 0.0.0.0:52300 *:*
UDP 0.0.0.0:52301 *:*
UDP 0.0.0.0:52302 *:*
UDP 0.0.0.0:52303 *:*
UDP 0.0.0.0:52304 *:*
UDP 0.0.0.0:52305 *:*
UDP 0.0.0.0:52306 *:*
UDP 0.0.0.0:52307 *:*
UDP 0.0.0.0:52308 *:*
UDP 0.0.0.0:52309 *:*
UDP 0.0.0.0:52310 *:*
UDP 0.0.0.0:52311 *:*
UDP 0.0.0.0:52312 *:*
UDP 0.0.0.0:52313 *:*
UDP 0.0.0.0:52314 *:*
UDP 0.0.0.0:52315 *:*
UDP 0.0.0.0:52316 *:*
UDP 0.0.0.0:52317 *:*
UDP 0.0.0.0:52318 *:*
UDP 0.0.0.0:52319 *:*
UDP 0.0.0.0:52320 *:*
UDP 0.0.0.0:52321 *:*
UDP 0.0.0.0:52322 *:*
UDP 0.0.0.0:52323 *:*
UDP 0.0.0.0:52324 *:*
UDP 0.0.0.0:52325 *:*
UDP 0.0.0.0:52326 *:*
UDP 0.0.0.0:52327 *:*
UDP 0.0.0.0:52328 *:*
UDP 0.0.0.0:52329 *:*
UDP 0.0.0.0:52330 *:*
UDP 0.0.0.0:52331 *:*
UDP 0.0.0.0:52332 *:*
UDP 0.0.0.0:52333 *:*
UDP 0.0.0.0:52334 *:*
UDP 0.0.0.0:52335 *:*
UDP 0.0.0.0:52336 *:*
UDP 0.0.0.0:52337 *:*
UDP 0.0.0.0:52338 *:*
UDP 0.0.0.0:52339 *:*
UDP 0.0.0.0:52340 *:*
UDP 0.0.0.0:52341 *:*
UDP 0.0.0.0:52342 *:*
UDP 0.0.0.0:52343 *:*
UDP 0.0.0.0:52344 *:*
UDP 0.0.0.0:52345 *:*
UDP 0.0.0.0:52346 *:*
UDP 0.0.0.0:52347 *:*
UDP 0.0.0.0:52348 *:*
UDP 0.0.0.0:52349 *:*
UDP 0.0.0.0:52350 *:*
UDP 0.0.0.0:52351 *:*
UDP 0.0.0.0:52352 *:*
UDP 0.0.0.0:52353 *:*
UDP 0.0.0.0:52354 *:*
UDP 0.0.0.0:52355 *:*
UDP 0.0.0.0:52356 *:*
UDP 0.0.0.0:52357 *:*
UDP 0.0.0.0:52358 *:*
UDP 0.0.0.0:52359 *:*
UDP 0.0.0.0:52360 *:*
UDP 0.0.0.0:52361 *:*
UDP 0.0.0.0:52362 *:*
UDP 0.0.0.0:52363 *:*
UDP 0.0.0.0:52364 *:*
UDP 0.0.0.0:52365 *:*
UDP 0.0.0.0:52366 *:*
UDP 0.0.0.0:52367 *:*
UDP 0.0.0.0:52368 *:*
UDP 0.0.0.0:52369 *:*
UDP 0.0.0.0:52370 *:*
UDP 0.0.0.0:52371 *:*
UDP 0.0.0.0:52372 *:*
UDP 0.0.0.0:52373 *:*
UDP 0.0.0.0:52374 *:*
UDP 0.0.0.0:52375 *:*
UDP 0.0.0.0:52376 *:*
UDP 0.0.0.0:52377 *:*
UDP 0.0.0.0:52378 *:*
UDP 0.0.0.0:52379 *:*
UDP 0.0.0.0:52380 *:*
UDP 0.0.0.0:52381 *:*
UDP 0.0.0.0:52382 *:*
UDP 0.0.0.0:52383 *:*
UDP 0.0.0.0:52384 *:*
UDP 0.0.0.0:52385 *:*
UDP 0.0.0.0:52386 *:*
UDP 0.0.0.0:52387 *:*
UDP 0.0.0.0:52388 *:*
UDP 0.0.0.0:52389 *:*
UDP 0.0.0.0:52390 *:*
UDP 0.0.0.0:52391 *:*
UDP 0.0.0.0:52392 *:*
UDP 0.0.0.0:52393 *:*
UDP 0.0.0.0:52394 *:*
UDP 0.0.0.0:52395 *:*
UDP 0.0.0.0:52396 *:*
UDP 0.0.0.0:52397 *:*
UDP 0.0.0.0:52398 *:*
UDP 0.0.0.0:52399 *:*
UDP 0.0.0.0:52400 *:*
UDP 0.0.0.0:52401 *:*
UDP 0.0.0.0:52402 *:*
UDP 0.0.0.0:52403 *:*
UDP 0.0.0.0:52404 *:*
UDP 0.0.0.0:52405 *:*
UDP 0.0.0.0:52406 *:*
UDP 0.0.0.0:52407 *:*
UDP 0.0.0.0:52408 *:*
UDP 0.0.0.0:52409 *:*
UDP 0.0.0.0:52410 *:*
UDP 0.0.0.0:52411 *:*
UDP 0.0.0.0:52412 *:*
UDP 0.0.0.0:52413 *:*
UDP 0.0.0.0:52414 *:*
UDP 0.0.0.0:52415 *:*
UDP 0.0.0.0:52416 *:*
UDP 0.0.0.0:52417 *:*
UDP 0.0.0.0:52418 *:*
UDP 0.0.0.0:52419 *:*
UDP 0.0.0.0:52420 *:*
UDP 0.0.0.0:52421 *:*
UDP 0.0.0.0:52422 *:*
UDP 0.0.0.0:52423 *:*
UDP 0.0.0.0:52424 *:*
UDP 0.0.0.0:52425 *:*
UDP 0.0.0.0:52426 *:*
UDP 0.0.0.0:52427 *:*
UDP 0.0.0.0:52428 *:*
UDP 0.0.0.0:52429 *:*
UDP 0.0.0.0:52430 *:*
UDP 0.0.0.0:52431 *:*
UDP 0.0.0.0:52432 *:*
UDP 0.0.0.0:52433 *:*
UDP 0.0.0.0:52434 *:*
UDP 0.0.0.0:52435 *:*
UDP 0.0.0.0:52436 *:*
UDP 0.0.0.0:52437 *:*
UDP 0.0.0.0:52438 *:*
UDP 0.0.0.0:52439 *:*
UDP 0.0.0.0:52440 *:*
UDP 0.0.0.0:52441 *:*
UDP 0.0.0.0:52442 *:*
UDP 0.0.0.0:52443 *:*
UDP 0.0.0.0:52444 *:*
UDP 0.0.0.0:52445 *:*
UDP 0.0.0.0:52446 *:*
UDP 0.0.0.0:52447 *:*
UDP 0.0.0.0:52448 *:*
UDP 0.0.0.0:52449 *:*
UDP 0.0.0.0:52450 *:*
UDP 0.0.0.0:52451 *:*
UDP 0.0.0.0:52452 *:*
UDP 0.0.0.0:52453 *:*
UDP 0.0.0.0:52454 *:*
UDP 0.0.0.0:52455 *:*
UDP 0.0.0.0:52456 *:*
UDP 0.0.0.0:52457 *:*
UDP 0.0.0.0:52458 *:*
UDP 0.0.0.0:52459 *:*
UDP 0.0.0.0:52460 *:*
UDP 0.0.0.0:52461 *:*
UDP 0.0.0.0:52462 *:*
UDP 0.0.0.0:52463 *:*
UDP 0.0.0.0:52464 *:*
UDP 0.0.0.0:52465 *:*
UDP 0.0.0.0:52466 *:*
UDP 0.0.0.0:52467 *:*
UDP 0.0.0.0:52468 *:*
UDP 0.0.0.0:52469 *:*
UDP 0.0.0.0:52470 *:*
UDP 0.0.0.0:52471 *:*
UDP 0.0.0.0:52472 *:*
UDP 0.0.0.0:52473 *:*
UDP 0.0.0.0:52474 *:*
UDP 0.0.0.0:52475 *:*
UDP 0.0.0.0:52476 *:*
UDP 0.0.0.0:52477 *:*
UDP 0.0.0.0:52478 *:*
UDP 0.0.0.0:52479 *:*
UDP 0.0.0.0:52480 *:*
UDP 0.0.0.0:52481 *:*
UDP 0.0.0.0:52482 *:*
UDP 0.0.0.0:52483 *:*
UDP 0.0.0.0:52484 *:*
UDP 0.0.0.0:52485 *:*
UDP 0.0.0.0:52486 *:*
UDP 0.0.0.0:52487 *:*
UDP 0.0.0.0:52488 *:*
UDP 0.0.0.0:52489 *:*
UDP 0.0.0.0:52490 *:*
UDP 0.0.0.0:52491 *:*
UDP 0.0.0.0:52492 *:*
UDP 0.0.0.0:52493 *:*
UDP 0.0.0.0:52494 *:*
UDP 0.0.0.0:52495 *:*
UDP 0.0.0.0:52496 *:*
UDP 0.0.0.0:52497 *:*
UDP 0.0.0.0:52498 *:*
UDP 0.0.0.0:52499 *:*
UDP 0.0.0.0:52500 *:*
UDP 0.0.0.0:52501 *:*
UDP 0.0.0.0:52502 *:*
UDP 0.0.0.0:52503 *:*
UDP 0.0.0.0:52504 *:*
UDP 0.0.0.0:52505 *:*
UDP 0.0.0.0:52506 *:*
UDP 0.0.0.0:52507 *:*
UDP 0.0.0.0:52508 *:*
UDP 0.0.0.0:52509 *:*
UDP 0.0.0.0:52510 *:*
UDP 0.0.0.0:52511 *:*
UDP 0.0.0.0:52512 *:*
UDP 0.0.0.0:52513 *:*
UDP 0.0.0.0:52514 *:*
UDP 0.0.0.0:52515 *:*
UDP 0.0.0.0:52516 *:*
UDP 0.0.0.0:52517 *:*
UDP 0.0.0.0:52518 *:*
UDP 0.0.0.0:52519 *:*
UDP 0.0.0.0:52520 *:*
UDP 0.0.0.0:52521 *:*
UDP 0.0.0.0:52522 *:*
UDP 0.0.0.0:52523 *:*
UDP 0.0.0.0:52524 *:*
UDP 0.0.0.0:52525 *:*
UDP 0.0.0.0:52526 *:*
UDP 0.0.0.0:52527 *:*
UDP 0.0.0.0:52528 *:*
UDP 0.0.0.0:52529 *:*
UDP 0.0.0.0:52530 *:*
UDP 0.0.0.0:52531 *:*
UDP 0.0.0.0:52532 *:*
UDP 0.0.0.0:52533 *:*
UDP 0.0.0.0:52534 *:*
UDP 0.0.0.0:52535 *:*
UDP 0.0.0.0:52536 *:*
UDP 0.0.0.0:52537 *:*
UDP 0.0.0.0:52538 *:*
UDP 0.0.0.0:52539 *:*
UDP 0.0.0.0:52540 *:*
UDP 0.0.0.0:52541 *:*
UDP 0.0.0.0:52542 *:*
UDP 0.0.0.0:52543 *:*
UDP 0.0.0.0:52544 *:*
UDP 0.0.0.0:52545 *:*
UDP 0.0.0.0:52546 *:*
UDP 0.0.0.0:52547 *:*
UDP 0.0.0.0:52548 *:*
UDP 0.0.0.0:52549 *:*
UDP 0.0.0.0:52550 *:*
UDP 0.0.0.0:52551 *:*
UDP 0.0.0.0:52552 *:*
UDP 0.0.0.0:52553 *:*
UDP 0.0.0.0:52554 *:*
UDP 0.0.0.0:52555 *:*
UDP 0.0.0.0:52556 *:*
UDP 0.0.0.0:52557 *:*
UDP 0.0.0.0:52558 *:*
UDP 0.0.0.0:52559 *:*
UDP 0.0.0.0:52560 *:*
UDP 0.0.0.0:52561 *:*
UDP 0.0.0.0:52562 *:*
UDP 0.0.0.0:52563 *:*
UDP 0.0.0.0:52564 *:*
UDP 0.0.0.0:52565 *:*
UDP 0.0.0.0:52566 *:*
UDP 0.0.0.0:52567 *:*
UDP 0.0.0.0:52568 *:*
UDP 0.0.0.0:52569 *:*
UDP 0.0.0.0:52570 *:*
UDP 0.0.0.0:52571 *:*
UDP 0.0.0.0:52572 *:*
UDP 0.0.0.0:52573 *:*
UDP 0.0.0.0:52574 *:*
UDP 0.0.0.0:52575 *:*
UDP 0.0.0.0:52576 *:*
UDP 0.0.0.0:52577 *:*
UDP 0.0.0.0:52578 *:*
UDP 0.0.0.0:52579 *:*
UDP 0.0.0.0:52580 *:*
UDP 0.0.0.0:52581 *:*
UDP 0.0.0.0:52582 *:*
UDP 0.0.0.0:52583 *:*
UDP 0.0.0.0:52584 *:*
UDP 0.0.0.0:52585 *:*
UDP 0.0.0.0:52586 *:*
UDP 0.0.0.0:52587 *:*
UDP 0.0.0.0:52588 *:*
UDP 0.0.0.0:52589 *:*
UDP 0.0.0.0:52590 *:*
UDP 0.0.0.0:52591 *:*
UDP 0.0.0.0:52592 *:*
UDP 0.0.0.0:52593 *:*
UDP 0.0.0.0:52594 *:*
UDP 0.0.0.0:52595 *:*
UDP 0.0.0.0:52596 *:*
UDP 0.0.0.0:52597 *:*
UDP 0.0.0.0:52598 *:*
UDP 0.0.0.0:52599 *:*
UDP 0.0.0.0:52600 *:*
UDP 0.0.0.0:52601 *:*
UDP 0.0.0.0:52602 *:*
UDP 0.0.0.0:52603 *:*
UDP 0.0.0.0:52604 *:*
UDP 0.0.0.0:52605 *:*
UDP 0.0.0.0:52606 *:*
UDP 0.0.0.0:52607 *:*
UDP 0.0.0.0:52608 *:*
UDP 0.0.0.0:52609 *:*
UDP 0.0.0.0:52610 *:*
UDP 0.0.0.0:52611 *:*
UDP 0.0.0.0:52612 *:*
UDP 0.0.0.0:52613 *:*
UDP 0.0.0.0:52614 *:*
UDP 0.0.0.0:52615 *:*
UDP 0.0.0.0:52616 *:*
UDP 0.0.0.0:52617 *:*
UDP 0.0.0.0:52618 *:*
UDP 0.0.0.0:52619 *:*
UDP 0.0.0.0:52620 *:*
UDP 0.0.0.0:52621 *:*
UDP 0.0.0.0:52622 *:*
UDP 0.0.0.0:52623 *:*
UDP 0.0.0.0:52624 *:*
UDP 0.0.0.0:52625 *:*
UDP 0.0.0.0:52626 *:*
UDP 0.0.0.0:52627 *:*
UDP 0.0.0.0:52628 *:*
UDP 0.0.0.0:52629 *:*
UDP 0.0.0.0:52630 *:*
UDP 0.0.0.0:52631 *:*
UDP 0.0.0.0:52632 *:*
UDP 0.0.0.0:52633 *:*
UDP 0.0.0.0:52634 *:*
UDP 0.0.0.0:52635 *:*
UDP 0.0.0.0:52636 *:*
UDP 0.0.0.0:52637 *:*
UDP 0.0.0.0:52638 *:*
UDP 0.0.0.0:52639 *:*
UDP 0.0.0.0:52640 *:*
UDP 0.0.0.0:52641 *:*
UDP 0.0.0.0:52642 *:*
UDP 0.0.0.0:52643 *:*
UDP 0.0.0.0:52644 *:*
UDP 0.0.0.0:52645 *:*
UDP 0.0.0.0:52646 *:*
UDP 0.0.0.0:52647 *:*
UDP 0.0.0.0:52648 *:*
UDP 0.0.0.0:52649 *:*
UDP 0.0.0.0:52650 *:*
UDP 0.0.0.0:52651 *:*
UDP 0.0.0.0:52652 *:*
UDP 0.0.0.0:52653 *:*
UDP 0.0.0.0:52654 *:*
UDP 0.0.0.0:52655 *:*
UDP 0.0.0.0:52656 *:*
UDP 0.0.0.0:52657 *:*
UDP 0.0.0.0:52658 *:*
UDP 0.0.0.0:52659 *:*
UDP 0.0.0.0:52660 *:*
UDP 0.0.0.0:52661 *:*
UDP 0.0.0.0:52662 *:*
UDP 0.0.0.0:52663 *:*
UDP 0.0.0.0:52664 *:*
UDP 0.0.0.0:52665 *:*
UDP 0.0.0.0:52666 *:*
UDP 0.0.0.0:52667 *:*
UDP 0.0.0.0:52668 *:*
UDP 0.0.0.0:52669 *:*
UDP 0.0.0.0:52670 *:*
UDP 0.0.0.0:52671 *:*
UDP 0.0.0.0:52672 *:*
UDP 0.0.0.0:52673 *:*
UDP 0.0.0.0:52674 *:*
UDP 0.0.0.0:52675 *:*
UDP 0.0.0.0:52676 *:*
UDP 0.0.0.0:52677 *:*
UDP 0.0.0.0:52678 *:*
UDP 0.0.0.0:52679 *:*
UDP 0.0.0.0:52680 *:*
UDP 0.0.0.0:52681 *:*
UDP 0.0.0.0:52682 *:*
UDP 0.0.0.0:52683 *:*
UDP 0.0.0.0:52684 *:*
UDP 0.0.0.0:52685 *:*
UDP 0.0.0.0:52686 *:*
UDP 0.0.0.0:52687 *:*
UDP 0.0.0.0:52688 *:*
UDP 0.0.0.0:52689 *:*
UDP 0.0.0.0:52690 *:*
UDP 0.0.0.0:52691 *:*
UDP 0.0.0.0:52692 *:*
UDP 0.0.0.0:52693 *:*
UDP 0.0.0.0:52694 *:*
UDP 0.0.0.0:52695 *:*
UDP 0.0.0.0:52696 *:*
UDP 0.0.0.0:52697 *:*
UDP 0.0.0.0:52698 *:*
UDP 0.0.0.0:52699 *:*
UDP 0.0.0.0:52700 *:*
UDP 0.0.0.0:52701 *:*
UDP 0.0.0.0:52702 *:*
UDP 0.0.0.0:52703 *:*
UDP 0.0.0.0:52704 *:*
UDP 0.0.0.0:52705 *:*
UDP 0.0.0.0:52706 *:*
UDP 0.0.0.0:52707 *:*
UDP 0.0.0.0:52708 *:*
UDP 0.0.0.0:52709 *:*
UDP 0.0.0.0:52710 *:*
UDP 0.0.0.0:52711 *:*
UDP 0.0.0.0:52712 *:*
UDP 0.0.0.0:52713 *:*
UDP 0.0.0.0:52714 *:*
UDP 0.0.0.0:52715 *:*
UDP 0.0.0.0:52716 *:*
UDP 0.0.0.0:52717 *:*
UDP 0.0.0.0:52718 *:*
UDP 0.0.0.0:52719 *:*
UDP 0.0.0.0:52720 *:*
UDP 0.0.0.0:52721 *:*
UDP 0.0.0.0:52722 *:*
UDP 0.0.0.0:52723 *:*
UDP 0.0.0.0:52724 *:*
UDP 0.0.0.0:52725 *:*
UDP 0.0.0.0:52726 *:*
UDP 0.0.0.0:52727 *:*
UDP 0.0.0.0:52728 *:*
UDP 0.0.0.0:52729 *:*
UDP 0.0.0.0:52730 *:*
UDP 0.0.0.0:52731 *:*
UDP 0.0.0.0:52732 *:*
UDP 0.0.0.0:52733 *:*
UDP 0.0.0.0:52734 *:*
UDP 0.0.0.0:52735 *:*
UDP 0.0.0.0:52736 *:*
UDP 0.0.0.0:52737 *:*
UDP 0.0.0.0:52738 *:*
UDP 0.0.0.0:52739 *:*
UDP 0.0.0.0:52740 *:*
UDP 0.0.0.0:52741 *:*
UDP 0.0.0.0:52742 *:*
UDP 0.0.0.0:52743 *:*
UDP 0.0.0.0:52744 *:*
UDP 0.0.0.0:52745 *:*
UDP 0.0.0.0:52746 *:*
UDP 0.0.0.0:52747 *:*
UDP 0.0.0.0:52748 *:*
UDP 0.0.0.0:52749 *:*
UDP 0.0.0.0:52750 *:*
UDP 0.0.0.0:52751 *:*
UDP 0.0.0.0:52752 *:*
UDP 0.0.0.0:52753 *:*
UDP 0.0.0.0:52754 *:*
UDP 0.0.0.0:52755 *:*
UDP 0.0.0.0:52756 *:*
UDP 0.0.0.0:52757 *:*
UDP 0.0.0.0:52758 *:*
UDP 0.0.0.0:52759 *:*
UDP 0.0.0.0:52760 *:*
UDP 0.0.0.0:52761 *:*
UDP 0.0.0.0:52762 *:*
UDP 0.0.0.0:52763 *:*
UDP 0.0.0.0:52764 *:*
UDP 0.0.0.0:52765 *:*
UDP 0.0.0.0:52766 *:*
UDP 0.0.0.0:52767 *:*
UDP 0.0.0.0:52768 *:*
UDP 0.0.0.0:52769 *:*
UDP 0.0.0.0:52770 *:*
UDP 0.0.0.0:52771 *:*
UDP 0.0.0.0:52772 *:*
UDP 0.0.0.0:52773 *:*
UDP 0.0.0.0:52774 *:*
UDP 0.0.0.0:52775 *:*
UDP 0.0.0.0:52776 *:*
UDP 0.0.0.0:52777 *:*
UDP 0.0.0.0:52778 *:*
UDP 0.0.0.0:52779 *:*
UDP 0.0.0.0:52780 *:*
UDP 0.0.0.0:52781 *:*
UDP 0.0.0.0:52782 *:*
UDP 0.0.0.0:52783 *:*
UDP 0.0.0.0:52784 *:*
UDP 0.0.0.0:52785 *:*
UDP 0.0.0.0:52786 *:*
UDP 0.0.0.0:52787 *:*
UDP 0.0.0.0:52788 *:*
UDP 0.0.0.0:52789 *:*
UDP 0.0.0.0:52790 *:*
UDP 0.0.0.0:52791 *:*
UDP 0.0.0.0:52792 *:*
UDP 0.0.0.0:52793 *:*
UDP 0.0.0.0:52794 *:*
UDP 0.0.0.0:52795 *:*
UDP 0.0.0.0:52796 *:*
UDP 0.0.0.0:52797 *:*
UDP 0.0.0.0:52798 *:*
UDP 0.0.0.0:52799 *:*
UDP 0.0.0.0:52800 *:*
UDP 0.0.0.0:52801 *:*
UDP 0.0.0.0:52802 *:*
UDP 0.0.0.0:52803 *:*
UDP 0.0.0.0:52804 *:*
UDP 0.0.0.0:52805 *:*
UDP 0.0.0.0:52806 *:*
UDP 0.0.0.0:52807 *:*
UDP 0.0.0.0:52808 *:*
UDP 0.0.0.0:52809 *:*
UDP 0.0.0.0:52810 *:*
UDP 0.0.0.0:52811 *:*
UDP 0.0.0.0:52812 *:*
UDP 0.0.0.0:52813 *:*
UDP 0.0.0.0:52814 *:*
UDP 0.0.0.0:52815 *:*
UDP 0.0.0.0:52816 *:*
UDP 0.0.0.0:52817 *:*
UDP 0.0.0.0:52818 *:*
UDP 0.0.0.0:52819 *:*
UDP 0.0.0.0:52820 *:*
UDP 0.0.0.0:52821 *:*
UDP 0.0.0.0:52822 *:*
UDP 0.0.0.0:52823 *:*
UDP 0.0.0.0:52824 *:*
UDP 0.0.0.0:52825 *:*
UDP 0.0.0.0:52826 *:*
UDP 0.0.0.0:52827 *:*
UDP 0.0.0.0:52828 *:*
UDP 0.0.0.0:52829 *:*
UDP 0.0.0.0:52830 *:*
UDP 0.0.0.0:52831 *:*
UDP 0.0.0.0:52832 *:*
UDP 0.0.0.0:52833 *:*
UDP 0.0.0.0:52834 *:*
UDP 0.0.0.0:52835 *:*
UDP 0.0.0.0:52836 *:*
UDP 0.0.0.0:52837 *:*
UDP 0.0.0.0:52838 *:*
UDP 0.0.0.0:52839 *:*
UDP 0.0.0.0:52840 *:*
UDP 0.0.0.0:52841 *:*
UDP 0.0.0.0:52842 *:*
UDP 0.0.0.0:52843 *:*
UDP 0.0.0.0:52844 *:*
UDP 0.0.0.0:52845 *:*
UDP 0.0.0.0:52846 *:*
UDP 0.0.0.0:52847 *:*
UDP 0.0.0.0:52848 *:*
UDP 0.0.0.0:52849 *:*
UDP 0.0.0.0:52850 *:*
UDP 0.0.0.0:52851 *:*
UDP 0.0.0.0:52852 *:*
UDP 0.0.0.0:52853 *:*
UDP 0.0.0.0:52854 *:*
UDP 0.0.0.0:52855 *:*
UDP 0.0.0.0:52856 *:*
UDP 0.0.0.0:52857 *:*
UDP 0.0.0.0:52858 *:*
UDP 0.0.0.0:52859 *:*
UDP 0.0.0.0:52860 *:*
UDP 0.0.0.0:52861 *:*
UDP 0.0.0.0:52862 *:*
UDP 0.0.0.0:52863 *:*
UDP 0.0.0.0:52864 *:*
UDP 0.0.0.0:52865 *:*
UDP 0.0.0.0:52866 *:*
UDP 0.0.0.0:52867 *:*
UDP 0.0.0.0:52868 *:*
UDP 0.0.0.0:52869 *:*
UDP 0.0.0.0:52870 *:*
UDP 0.0.0.0:52871 *:*
UDP 0.0.0.0:52872 *:*
UDP 0.0.0.0:52873 *:*
UDP 0.0.0.0:52874 *:*
UDP 0.0.0.0:52875 *:*
UDP 0.0.0.0:52876 *:*
UDP 0.0.0.0:52877 *:*
UDP 0.0.0.0:52878 *:*
UDP 0.0.0.0:52879 *:*
UDP 0.0.0.0:52880 *:*
UDP 0.0.0.0:52881 *:*
UDP 0.0.0.0:52882 *:*
UDP 0.0.0.0:52883 *:*
UDP 0.0.0.0:52884 *:*
UDP 0.0.0.0:52885 *:*
UDP 0.0.0.0:52886 *:*
UDP 0.0.0.0:52887 *:*
UDP 0.0.0.0:52888 *:*
UDP 0.0.0.0:52889 *:*
UDP 0.0.0.0:52890 *:*
UDP 0.0.0.0:52891 *:*
UDP 0.0.0.0:52892 *:*
UDP 0.0.0.0:52893 *:*
UDP 0.0.0.0:52894 *:*
UDP 0.0.0.0:52895 *:*
UDP 0.0.0.0:52896 *:*
UDP 0.0.0.0:52897 *:*
UDP 0.0.0.0:52898 *:*
UDP 0.0.0.0:52899 *:*
UDP 0.0.0.0:52900 *:*
UDP 0.0.0.0:52901 *:*
UDP 0.0.0.0:52902 *:*
UDP 0.0.0.0:52903 *:*
UDP 0.0.0.0:52904 *:*
UDP 0.0.0.0:52905 *:*
UDP 0.0.0.0:52906 *:*
UDP 0.0.0.0:52907 *:*
UDP 0.0.0.0:52908 *:*
UDP 0.0.0.0:52909 *:*
UDP 0.0.0.0:52910 *:*
UDP 0.0.0.0:52911 *:*
UDP 0.0.0.0:52912 *:*
UDP 0.0.0.0:52913 *:*
UDP 0.0.0.0:52914 *:*
UDP 0.0.0.0:52915 *:*
UDP 0.0.0.0:52916 *:*
UDP 0.0.0.0:52917 *:*
UDP 0.0.0.0:52918 *:*
UDP 0.0.0.0:52919 *:*
UDP 0.0.0.0:52920 *:*
UDP 0.0.0.0:52921 *:*
UDP 0.0.0.0:52922 *:*
UDP 0.0.0.0:52923 *:*
UDP 0.0.0.0:52924 *:*
UDP 0.0.0.0:52925 *:*
UDP 0.0.0.0:52926 *:*
UDP 0.0.0.0:52927 *:*
UDP 0.0.0.0:52928 *:*
UDP 0.0.0.0:52929 *:*
UDP 0.0.0.0:52930 *:*
UDP 0.0.0.0:52931 *:*
UDP 0.0.0.0:52932 *:*
UDP 0.0.0.0:52933 *:*
UDP 0.0.0.0:52934 *:*
UDP 0.0.0.0:52935 *:*
UDP 0.0.0.0:52936 *:*
UDP 0.0.0.0:52937 *:*
UDP 0.0.0.0:52938 *:*
UDP 0.0.0.0:52939 *:*
UDP 0.0.0.0:52940 *:*
UDP 0.0.0.0:52941 *:*
UDP 0.0.0.0:52942 *:*
UDP 0.0.0.0:52943 *:*
UDP 0.0.0.0:52944 *:*
UDP 0.0.0.0:52945 *:*
UDP 0.0.0.0:52946 *:*
UDP 0.0.0.0:52947 *:*
UDP 0.0.0.0:52948 *:*
UDP 0.0.0.0:52949 *:*
UDP 0.0.0.0:52950 *:*
UDP 0.0.0.0:52951 *:*
UDP 0.0.0.0:52952 *:*
UDP 0.0.0.0:52953 *:*
UDP 0.0.0.0:52954 *:*
UDP 0.0.0.0:52955 *:*
UDP 0.0.0.0:52956 *:*
UDP 0.0.0.0:52957 *:*
UDP 0.0.0.0:52958 *:*
UDP 0.0.0.0:52959 *:*
UDP 0.0.0.0:52960 *:*
UDP 0.0.0.0:52961 *:*
UDP 0.0.0.0:52962 *:*
UDP 0.0.0.0:52963 *:*
UDP 0.0.0.0:52964 *:*
UDP 0.0.0.0:52965 *:*
UDP 0.0.0.0:52966 *:*
UDP 0.0.0.0:52967 *:*
UDP 0.0.0.0:52968 *:*
UDP 0.0.0.0:52969 *:*
UDP 0.0.0.0:52970 *:*
UDP 0.0.0.0:52971 *:*
UDP 0.0.0.0:52972 *:*
UDP 0.0.0.0:52973 *:*
UDP 0.0.0.0:52974 *:*
UDP 0.0.0.0:52975 *:*
UDP 0.0.0.0:52976 *:*
UDP 0.0.0.0:52977 *:*
UDP 0.0.0.0:52978 *:*
UDP 0.0.0.0:52979 *:*
UDP 0.0.0.0:52980 *:*
UDP 0.0.0.0:52981 *:*
UDP 0.0.0.0:52982 *:*
UDP 0.0.0.0:52983 *:*
UDP 0.0.0.0:52984 *:*
UDP 0.0.0.0:52985 *:*
UDP 0.0.0.0:52986 *:*
UDP 0.0.0.0:52987 *:*
UDP 0.0.0.0:52988 *:*
UDP 0.0.0.0:52989 *:*
UDP 0.0.0.0:52990 *:*
UDP 0.0.0.0:52991 *:*
UDP 0.0.0.0:52992 *:*
UDP 0.0.0.0:52993 *:*
UDP 0.0.0.0:52994 *:*
UDP 0.0.0.0:52995 *:*
UDP 0.0.0.0:52996 *:*
UDP 0.0.0.0:52997 *:*
UDP 0.0.0.0:52998 *:*
UDP 0.0.0.0:52999 *:*
UDP 0.0.0.0:53000 *:*
UDP 0.0.0.0:53001 *:*
UDP 0.0.0.0:53002 *:*
UDP 0.0.0.0:53003 *:*
UDP 0.0.0.0:53004 *:*
UDP 0.0.0.0:53005 *:*
UDP 0.0.0.0:53006 *:*
UDP 0.0.0.0:53007 *:*
UDP 0.0.0.0:53008 *:*
UDP 0.0.0.0:53009 *:*
UDP 0.0.0.0:53010 *:*
UDP 0.0.0.0:53011 *:*
UDP 0.0.0.0:53012 *:*
UDP 0.0.0.0:53013 *:*
UDP 0.0.0.0:53014 *:*
UDP 0.0.0.0:53015 *:*
UDP 0.0.0.0:53016 *:*
UDP 0.0.0.0:53017 *:*
UDP 0.0.0.0:53018 *:*
UDP 0.0.0.0:53019 *:*
UDP 0.0.0.0:53020 *:*
UDP 0.0.0.0:53021 *:*
UDP 0.0.0.0:53022 *:*
UDP 0.0.0.0:53023 *:*
UDP 0.0.0.0:53024 *:*
UDP 0.0.0.0:53025 *:*
UDP 0.0.0.0:53026 *:*
UDP 0.0.0.0:53027 *:*
UDP 0.0.0.0:53028 *:*
UDP 0.0.0.0:53029 *:*
UDP 0.0.0.0:53030 *:*
UDP 0.0.0.0:53031 *:*
UDP 0.0.0.0:53032 *:*
UDP 0.0.0.0:53033 *:*
UDP 0.0.0.0:53034 *:*
UDP 0.0.0.0:53035 *:*
UDP 0.0.0.0:53036 *:*
UDP 0.0.0.0:53037 *:*
UDP 0.0.0.0:53038 *:*
UDP 0.0.0.0:53039 *:*
UDP 0.0.0.0:53040 *:*
UDP 0.0.0.0:53041 *:*
UDP 0.0.0.0:53042 *:*
UDP 0.0.0.0:53043 *:*
UDP 0.0.0.0:53044 *:*
UDP 0.0.0.0:53045 *:*
UDP 0.0.0.0:53046 *:*
UDP 0.0.0.0:53047 *:*
UDP 0.0.0.0:53048 *:*
UDP 0.0.0.0:53049 *:*
UDP 0.0.0.0:53050 *:*
UDP 0.0.0.0:53051 *:*
UDP 0.0.0.0:53052 *:*
UDP 0.0.0.0:53053 *:*
UDP 0.0.0.0:53054 *:*
UDP 0.0.0.0:53055 *:*
UDP 0.0.0.0:53056 *:*
UDP 0.0.0.0:53057 *:*
UDP 0.0.0.0:53058 *:*
UDP 0.0.0.0:53059 *:*
UDP 0.0.0.0:53060 *:*
UDP 0.0.0.0:53061 *:*
UDP 0.0.0.0:53062 *:*
UDP 0.0.0.0:53063 *:*
UDP 0.0.0.0:53064 *:*
UDP 0.0.0.0:53065 *:*
UDP 0.0.0.0:53066 *:*
UDP 0.0.0.0:53067 *:*
UDP 0.0.0.0:53068 *:*
UDP 0.0.0.0:53069 *:*
UDP 0.0.0.0:53070 *:*
UDP 0.0.0.0:53071 *:*
UDP 0.0.0.0:53072 *:*
UDP 0.0.0.0:53073 *:*
UDP 0.0.0.0:53074 *:*
UDP 0.0.0.0:53075 *:*
UDP 0.0.0.0:53076 *:*
UDP 0.0.0.0:53077 *:*
UDP 0.0.0.0:53078 *:*
UDP 0.0.0.0:53079 *:*
UDP 0.0.0.0:53080 *:*
UDP 0.0.0.0:53081 *:*
UDP 0.0.0.0:53082 *:*
UDP 0.0.0.0:53083 *:*
UDP 0.0.0.0:53084 *:*
UDP 0.0.0.0:53085 *:*
UDP 0.0.0.0:53086 *:*
UDP 0.0.0.0:53087 *:*
UDP 0.0.0.0:53088 *:*
UDP 0.0.0.0:53089 *:*
UDP 0.0.0.0:53090 *:*
UDP 0.0.0.0:53091 *:*
UDP 0.0.0.0:53092 *:*
UDP 0.0.0.0:53093 *:*
UDP 0.0.0.0:53094 *:*
UDP 0.0.0.0:53095 *:*
UDP 0.0.0.0:53096 *:*
UDP 0.0.0.0:53097 *:*
UDP 0.0.0.0:53098 *:*
UDP 0.0.0.0:53099 *:*
UDP 0.0.0.0:53100 *:*
UDP 0.0.0.0:53101 *:*
UDP 0.0.0.0:53102 *:*
UDP 0.0.0.0:53103 *:*
UDP 0.0.0.0:53104 *:*
UDP 0.0.0.0:53105 *:*
UDP 0.0.0.0:53106 *:*
UDP 0.0.0.0:53107 *:*
UDP 0.0.0.0:53108 *:*
UDP 0.0.0.0:53109 *:*
UDP 0.0.0.0:53110 *:*
UDP 0.0.0.0:53111 *:*
UDP 0.0.0.0:53112 *:*
UDP 0.0.0.0:53113 *:*
UDP 0.0.0.0:53114 *:*
UDP 0.0.0.0:53115 *:*
UDP 0.0.0.0:53116 *:*
UDP 0.0.0.0:53117 *:*
UDP 0.0.0.0:53118 *:*
UDP 0.0.0.0:53119 *:*
UDP 0.0.0.0:53120 *:*
UDP 0.0.0.0:53121 *:*
UDP 0.0.0.0:53122 *:*
UDP 0.0.0.0:53123 *:*
UDP 0.0.0.0:53124 *:*
Active Connections
UDP 0.0.0.0:123 *:*
UDP 0.0.0.0:389 *:*
linearstack
UDP 0.0.0.0:53125 *:*
UDP 0.0.0.0:53126 *:*
UDP 0.0.0.0:53127 *:*
UDP 0.0.0.0:53128 *:*
UDP 0.0.0.0:53129 *:*
UDP 0.0.0.0:53130 *:*
UDP 0.0.0.0:53131 *:*
UDP 0.0.0.0:53132 *:*
UDP 0.0.0.0:53133 *:*
UDP 0.0.0.0:53134 *:*
UDP 0.0.0.0:53135 *:*
UDP 0.0.0.0:53136 *:*
UDP 0.0.0.0:53137 *:*
UDP 0.0.0.0:53138 *:*
UDP 0.0.0.0:53139 *:*
UDP 0.0.0.0:53140 *:*
UDP 0.0.0.0:53141 *:*
UDP 0.0.0.0:53142 *:*
UDP 0.0.0.0:53143 *:*
UDP 0.0.0.0:53144 *:*
UDP 0.0.0.0:53145 *:*
UDP 0.0.0.0:53146 *:*
UDP 0.0.0.0:53147 *:*
UDP 0.0.0.0:53148 *:*
UDP 0.0.0.0:53149 *:*
UDP 0.0.0.0:53150 *:*
UDP 0.0.0.0:53151 *:*
UDP 0.0.0.0:53152 *:*
UDP 0.0.0.0:53153 *:*
UDP 0.0.0.0:53154 *:*
UDP 0.0.0.0:53155 *:*
UDP 0.0.0.0:53156 *:*
UDP 0.0.0.0:53157 *:*
UDP 0.0.0.0:53158 *:*
UDP 0.0.0.0:53159 *:*
UDP 0.0.0.0:53160 *:*
UDP 0.0.0.0:53161 *:*
UDP 0.0.0.0:53162 *:*
UDP 0.0.0.0:53163 *:*
UDP 0.0.0.0:53164 *:*
UDP 0.0.0.0:53165 *:*
UDP 0.0.0.0:53166 *:*
UDP 0.0.0.0:53167 *:*
UDP 0.0.0.0:53168 *:*
UDP 0.0.0.0:53169 *:*
UDP 0.0.0.0:53170 *:*
UDP 0.0.0.0:53171 *:*
UDP 0.0.0.0:53172 *:*
UDP 0.0.0.0:53173 *:*
UDP 0.0.0.0:53174 *:*
UDP 0.0.0.0:53175 *:*
UDP 0.0.0.0:53176 *:*
UDP 0.0.0.0:53177 *:*
UDP 0.0.0.0:53178 *:*
UDP 0.0.0.0:53179 *:*
UDP 0.0.0.0:53180 *:*
UDP 0.0.0.0:53181 *:*
UDP 0.0.0.0:53182 *:*
UDP 0.0.0.0:53183 *:*
UDP 0.0.0.0:53184 *:*
UDP 0.0.0.0:53185 *:*
UDP 0.0.0.0:53186 *:*
UDP 0.0.0.0:53187 *:*
UDP 0.0.0.0:53188 *:*
UDP 0.0.0.0:53189 *:*
UDP 0.0.0.0:53190 *:*
UDP 0.0.0.0:53191 *:*
UDP 0.0.0.0:53192 *:*
UDP 0.0.0.0:53193 *:*
UDP 0.0.0.0:53194 *:*
UDP 0.0.0.0:53195 *:*
UDP 0.0.0.0:53196 *:*
UDP 0.0.0.0:53197 *:*
UDP 0.0.0.0:53198 *:*
UDP 0.0.0.0:53199 *:*
UDP 0.0.0.0:53200 *:*
UDP 0.0.0.0:53201 *:*
UDP 0.0.0.0:53202 *:*
UDP 0.0.0.0:53203 *:*
UDP 0.0.0.0:53204 *:*
UDP 0.0.0.0:53205 *:*
UDP 0.0.0.0:53206 *:*
UDP 0.0.0.0:53207 *:*
UDP 0.0.0.0:53208 *:*
UDP 0.0.0.0:53209 *:*
UDP 0.0.0.0:53210 *:*
UDP 0.0.0.0:53211 *:*
UDP 0.0.0.0:53212 *:*
UDP 0.0.0.0:53213 *:*
UDP 0.0.0.0:53214 *:*
UDP 0.0.0.0:53215 *:*
UDP 0.0.0.0:53216 *:*
UDP 0.0.0.0:53217 *:*
UDP 0.0.0.0:53218 *:*
UDP 0.0.0.0:53219 *:*
UDP 0.0.0.0:53220 *:*
UDP 0.0.0.0:53221 *:*
UDP 0.0.0.0:53222 *:*
UDP 0.0.0.0:53223 *:*
UDP 0.0.0.0:53224 *:*
UDP 0.0.0.0:53225 *:*
UDP 0.0.0.0:53226 *:*
UDP 0.0.0.0:53227 *:*
UDP 0.0.0.0:53228 *:*
UDP 0.0.0.0:53229 *:*
UDP 0.0.0.0:53230 *:*
UDP 0.0.0.0:53231 *:*
UDP 0.0.0.0:53232 *:*
UDP 0.0.0.0:53233 *:*
UDP 0.0.0.0:53234 *:*
UDP 0.0.0.0:53235 *:*
UDP 0.0.0.0:53236 *:*
UDP 0.0.0.0:53237 *:*
UDP 0.0.0.0:53238 *:*
UDP 0.0.0.0:53239 *:*
UDP 0.0.0.0:53240 *:*
UDP 0.0.0.0:53241 *:*
UDP 0.0.0.0:53242 *:*
UDP 0.0.0.0:53243 *:*
UDP 0.0.0.0:53244 *:*
UDP 0.0.0.0:53245 *:*
UDP 0.0.0.0:53246 *:*
UDP 0.0.0.0:53247 *:*
UDP 0.0.0.0:53248 *:*
UDP 0.0.0.0:53249 *:*
UDP 0.0.0.0:53250 *:*
UDP 0.0.0.0:53251 *:*
UDP 0.0.0.0:53252 *:*
UDP 0.0.0.0:53253 *:*
UDP 0.0.0.0:53254 *:*
UDP 0.0.0.0:53255 *:*
UDP 0.0.0.0:53256 *:*
UDP 0.0.0.0:53257 *:*
UDP 0.0.0.0:53258 *:*
UDP 0.0.0.0:53259 *:*
UDP 0.0.0.0:53260 *:*
UDP 0.0.0.0:53261 *:*
UDP 0.0.0.0:53262 *:*
UDP 0.0.0.0:53263 *:*
UDP 0.0.0.0:53264 *:*
UDP 0.0.0.0:53265 *:*
UDP 0.0.0.0:53266 *:*
UDP 0.0.0.0:53267 *:*
UDP 0.0.0.0:53268 *:*
UDP 0.0.0.0:53269 *:*
UDP 0.0.0.0:53270 *:*
UDP 0.0.0.0:53271 *:*
UDP 0.0.0.0:53272 *:*
UDP 0.0.0.0:53273 *:*
UDP 0.0.0.0:53274 *:*
UDP 0.0.0.0:53275 *:*
UDP 0.0.0.0:53276 *:*
UDP 0.0.0.0:53277 *:*
UDP 0.0.0.0:53278 *:*
UDP 0.0.0.0:53279 *:*
UDP 0.0.0.0:53280 *:*
UDP 0.0.0.0:53281 *:*
UDP 0.0.0.0:53282 *:*
UDP 0.0.0.0:53283 *:*
UDP 0.0.0.0:53284 *:*
UDP 0.0.0.0:53285 *:*
UDP 0.0.0.0:53286 *:*
UDP 0.0.0.0:53287 *:*
UDP 0.0.0.0:53288 *:*
UDP 0.0.0.0:53289 *:*
UDP 0.0.0.0:53290 *:*
UDP 0.0.0.0:53291 *:*
UDP 0.0.0.0:53292 *:*
UDP 0.0.0.0:53293 *:*
UDP 0.0.0.0:53294 *:*
UDP 0.0.0.0:53295 *:*
UDP 0.0.0.0:53296 *:*
UDP 0.0.0.0:53297 *:*
UDP 0.0.0.0:53298 *:*
UDP 0.0.0.0:53299 *:*
UDP 0.0.0.0:53300 *:*
UDP 0.0.0.0:53301 *:*
UDP 0.0.0.0:53302 *:*
UDP 0.0.0.0:53303 *:*
UDP 0.0.0.0:53304 *:*
UDP 0.0.0.0:53305 *:*
UDP 0.0.0.0:53306 *:*
UDP 0.0.0.0:53307 *:*
UDP 0.0.0.0:53308 *:*
UDP 0.0.0.0:53309 *:*
UDP 0.0.0.0:53310 *:*
UDP 0.0.0.0:53311 *:*
UDP 0.0.0.0:53312 *:*
UDP 0.0.0.0:53313 *:*
UDP 0.0.0.0:53314 *:*
UDP 0.0.0.0:53315 *:*
UDP 0.0.0.0:53316 *:*
UDP 0.0.0.0:53317 *:*
UDP 0.0.0.0:53318 *:*
UDP 0.0.0.0:53319 *:*
UDP 0.0.0.0:53320 *:*
UDP 0.0.0.0:53321 *:*
UDP 0.0.0.0:53322 *:*
UDP 0.0.0.0:53323 *:*
UDP 0.0.0.0:53324 *:*
UDP 0.0.0.0:53325 *:*
UDP 0.0.0.0:53326 *:*
UDP 0.0.0.0:53327 *:*
UDP 0.0.0.0:53328 *:*
UDP 0.0.0.0:53329 *:*
UDP 0.0.0.0:53330 *:*
UDP 0.0.0.0:53331 *:*
UDP 0.0.0.0:53332 *:*
UDP 0.0.0.0:53333 *:*
UDP 0.0.0.0:53334 *:*
UDP 0.0.0.0:53335 *:*
UDP 0.0.0.0:53336 *:*
UDP 0.0.0.0:53337 *:*
UDP 0.0.0.0:53338 *:*
UDP 0.0.0.0:53339 *:*
UDP 0.0.0.0:53340 *:*
UDP 0.0.0.0:53341 *:*
UDP 0.0.0.0:53342 *:*
UDP 0.0.0.0:53343 *:*
UDP 0.0.0.0:53344 *:*
UDP 0.0.0.0:53345 *:*
UDP 0.0.0.0:53346 *:*
UDP 0.0.0.0:53347 *:*
UDP 0.0.0.0:53348 *:*
UDP 0.0.0.0:53349 *:*
UDP 0.0.0.0:53350 *:*
UDP 0.0.0.0:53351 *:*
UDP 0.0.0.0:53352 *:*
UDP 0.0.0.0:53353 *:*
UDP 0.0.0.0:53354 *:*
UDP 0.0.0.0:53355 *:*
UDP 0.0.0.0:53356 *:*
UDP 0.0.0.0:53357 *:*
UDP 0.0.0.0:53358 *:*
UDP 0.0.0.0:53359 *:*
UDP 0.0.0.0:53360 *:*
UDP 0.0.0.0:53361 *:*
UDP 0.0.0.0:53362 *:*
UDP 0.0.0.0:53363 *:*
UDP 0.0.0.0:53364 *:*
UDP 0.0.0.0:53365 *:*
UDP 0.0.0.0:53366 *:*
UDP 0.0.0.0:53367 *:*
UDP 0.0.0.0:53368 *:*
UDP 0.0.0.0:53369 *:*
UDP 0.0.0.0:53370 *:*
UDP 0.0.0.0:53371 *:*
UDP 0.0.0.0:53372 *:*
UDP 0.0.0.0:53373 *:*
UDP 0.0.0.0:53374 *:*
UDP 0.0.0.0:53375 *:*
UDP 0.0.0.0:53376 *:*
UDP 0.0.0.0:53377 *:*
UDP 0.0.0.0:53378 *:*
UDP 0.0.0.0:53379 *:*
UDP 0.0.0.0:53380 *:*
UDP 0.0.0.0:53381 *:*
UDP 0.0.0.0:53382 *:*
UDP 0.0.0.0:53383 *:*
UDP 0.0.0.0:53384 *:*
UDP 0.0.0.0:53385 *:*
UDP 0.0.0.0:53386 *:*
UDP 0.0.0.0:53387 *:*
UDP 0.0.0.0:53388 *:*
UDP 0.0.0.0:53389 *:*
UDP 0.0.0.0:53390 *:*
UDP 0.0.0.0:53391 *:*
UDP 0.0.0.0:53392 *:*
UDP 0.0.0.0:53393 *:*
UDP 0.0.0.0:53394 *:*
UDP 0.0.0.0:53395 *:*
UDP 0.0.0.0:53396 *:*
UDP 0.0.0.0:53397 *:*
UDP 0.0.0.0:53398 *:*
UDP 0.0.0.0:53399 *:*
UDP 0.0.0.0:53400 *:*
UDP 0.0.0.0:53401 *:*
UDP 0.0.0.0:53402 *:*
UDP 0.0.0.0:53403 *:*
UDP 0.0.0.0:53404 *:*
UDP 0.0.0.0:53405 *:*
UDP 0.0.0.0:53406 *:*
UDP 0.0.0.0:53407 *:*
UDP 0.0.0.0:53408 *:*
UDP 0.0.0.0:53409 *:*
UDP 0.0.0.0:53410 *:*
UDP 0.0.0.0:53411 *:*
UDP 0.0.0.0:53412 *:*
UDP 0.0.0.0:53413 *:*
UDP 0.0.0.0:53414 *:*
UDP 0.0.0.0:53415 *:*
UDP 0.0.0.0:53416 *:*
UDP 0.0.0.0:53417 *:*
UDP 0.0.0.0:53418 *:*
UDP 0.0.0.0:53419 *:*
UDP 0.0.0.0:53420 *:*
UDP 0.0.0.0:53421 *:*
UDP 0.0.0.0:53422 *:*
UDP 0.0.0.0:53423 *:*
UDP 0.0.0.0:53424 *:*
UDP 0.0.0.0:53425 *:*
UDP 0.0.0.0:53426 *:*
UDP 0.0.0.0:53427 *:*
UDP 0.0.0.0:53428 *:*
UDP 0.0.0.0:53429 *:*
UDP 0.0.0.0:53430 *:*
UDP 0.0.0.0:53431 *:*
UDP 0.0.0.0:53432 *:*
UDP 0.0.0.0:53433 *:*
UDP 0.0.0.0:53434 *:*
UDP 0.0.0.0:53435 *:*
UDP 0.0.0.0:53436 *:*
UDP 0.0.0.0:53437 *:*
UDP 0.0.0.0:53438 *:*
UDP 0.0.0.0:53439 *:*
UDP 0.0.0.0:53440 *:*
UDP 0.0.0.0:53441 *:*
UDP 0.0.0.0:53442 *:*
UDP 0.0.0.0:53443 *:*
UDP 0.0.0.0:53444 *:*
UDP 0.0.0.0:53445 *:*
UDP 0.0.0.0:53446 *:*
UDP 0.0.0.0:53447 *:*
UDP 0.0.0.0:53448 *:*
UDP 0.0.0.0:53449 *:*
UDP 0.0.0.0:53450 *:*
UDP 0.0.0.0:53451 *:*
UDP 0.0.0.0:53452 *:*
UDP 0.0.0.0:53453 *:*
UDP 0.0.0.0:53454 *:*
UDP 0.0.0.0:53455 *:*
UDP 0.0.0.0:53456 *:*
UDP 0.0.0.0:53457 *:*
UDP 0.0.0.0:53458 *:*
UDP 0.0.0.0:53459 *:*
UDP 0.0.0.0:53460 *:*
UDP 0.0.0.0:53461 *:*
UDP 0.0.0.0:53462 *:*
UDP 0.0.0.0:53463 *:*
UDP 0.0.0.0:53464 *:*
UDP 0.0.0.0:53465 *:*
UDP 0.0.0.0:53466 *:*
UDP 0.0.0.0:53467 *:*
UDP 0.0.0.0:53468 *:*
UDP 0.0.0.0:53469 *:*
UDP 0.0.0.0:53470 *:*
UDP 0.0.0.0:53471 *:*
UDP 0.0.0.0:53472 *:*
UDP 0.0.0.0:53473 *:*
UDP 0.0.0.0:53474 *:*
UDP 0.0.0.0:53475 *:*
UDP 0.0.0.0:53476 *:*
UDP 0.0.0.0:53477 *:*
UDP 0.0.0.0:53478 *:*
UDP 0.0.0.0:53479 *:*
UDP 0.0.0.0:53480 *:*
UDP 0.0.0.0:53481 *:*
UDP 0.0.0.0:53482 *:*
UDP 0.0.0.0:53483 *:*
UDP 0.0.0.0:53484 *:*
UDP 0.0.0.0:53485 *:*
UDP 0.0.0.0:53486 *:*
UDP 0.0.0.0:53487 *:*
UDP 0.0.0.0:53488 *:*
UDP 0.0.0.0:53489 *:*
UDP 0.0.0.0:53490 *:*
UDP 0.0.0.0:53491 *:*
UDP 0.0.0.0:53492 *:*
UDP 0.0.0.0:53493 *:*
UDP 0.0.0.0:53494 *:*
UDP 0.0.0.0:53495 *:*
UDP 0.0.0.0:53496 *:*
UDP 0.0.0.0:53497 *:*
UDP 0.0.0.0:53498 *:*
UDP 0.0.0.0:53499 *:*
UDP 0.0.0.0:53500 *:*
UDP 0.0.0.0:53501 *:*
UDP 0.0.0.0:53502 *:*
UDP 0.0.0.0:53503 *:*
UDP 0.0.0.0:53504 *:*
UDP 0.0.0.0:53505 *:*
UDP 0.0.0.0:53506 *:*
UDP 0.0.0.0:53507 *:*
UDP 0.0.0.0:53508 *:*
UDP 0.0.0.0:53509 *:*
UDP 0.0.0.0:53510 *:*
UDP 0.0.0.0:53511 *:*
UDP 0.0.0.0:53512 *:*
UDP 0.0.0.0:53513 *:*
UDP 0.0.0.0:53514 *:*
UDP 0.0.0.0:53515 *:*
UDP 0.0.0.0:53516 *:*
UDP 0.0.0.0:53517 *:*
UDP 0.0.0.0:53518 *:*
UDP 0.0.0.0:53519 *:*
UDP 0.0.0.0:53520 *:*
UDP 0.0.0.0:53521 *:*
UDP 0.0.0.0:53522 *:*
UDP 0.0.0.0:53523 *:*
UDP 0.0.0.0:53524 *:*
UDP 0.0.0.0:53525 *:*
UDP 0.0.0.0:53526 *:*
UDP 0.0.0.0:53527 *:*
UDP 0.0.0.0:53528 *:*
UDP 0.0.0.0:53529 *:*
UDP 0.0.0.0:53530 *:*
UDP 0.0.0.0:53531 *:*
UDP 0.0.0.0:53532 *:*
UDP 0.0.0.0:53533 *:*
UDP 0.0.0.0:53534 *:*
UDP 0.0.0.0:53535 *:*
UDP 0.0.0.0:53536 *:*
UDP 0.0.0.0:53537 *:*
UDP 0.0.0.0:53538 *:*
UDP 0.0.0.0:53539 *:*
UDP 0.0.0.0:53540 *:*
UDP 0.0.0.0:53541 *:*
UDP 0.0.0.0:53542 *:*
UDP 0.0.0.0:53543 *:*
UDP 0.0.0.0:53544 *:*
UDP 0.0.0.0:53545 *:*
UDP 0.0.0.0:53546 *:*
UDP 0.0.0.0:53547 *:*
UDP 0.0.0.0:53548 *:*
UDP 0.0.0.0:53549 *:*
UDP 0.0.0.0:53550 *:*
UDP 0.0.0.0:53551 *:*
UDP 0.0.0.0:53552 *:*
UDP 0.0.0.0:53553 *:*
UDP 0.0.0.0:53554 *:*
UDP 0.0.0.0:53555 *:*
UDP 0.0.0.0:53556 *:*
UDP 0.0.0.0:53557 *:*
UDP 0.0.0.0:53558 *:*
UDP 0.0.0.0:53559 *:*
UDP 0.0.0.0:53560 *:*
UDP 0.0.0.0:53561 *:*
UDP 0.0.0.0:53562 *:*
UDP 0.0.0.0:53563 *:*
UDP 0.0.0.0:53564 *:*
UDP 0.0.0.0:53565 *:*
UDP 0.0.0.0:53566 *:*
UDP 0.0.0.0:53567 *:*
UDP 0.0.0.0:53568 *:*
UDP 0.0.0.0:53569 *:*
UDP 0.0.0.0:53570 *:*
UDP 0.0.0.0:53571 *:*
UDP 0.0.0.0:53572 *:*
UDP 0.0.0.0:53573 *:*
UDP 0.0.0.0:53574 *:*
UDP 0.0.0.0:53575 *:*
UDP 0.0.0.0:53576 *:*
UDP 0.0.0.0:53577 *:*
UDP 0.0.0.0:53578 *:*
UDP 0.0.0.0:53579 *:*
UDP 0.0.0.0:53580 *:*
UDP 0.0.0.0:53581 *:*
UDP 0.0.0.0:53582 *:*
UDP 0.0.0.0:53583 *:*
UDP 0.0.0.0:53584 *:*
UDP 0.0.0.0:53585 *:*
UDP 0.0.0.0:53586 *:*
UDP 0.0.0.0:53587 *:*
UDP 0.0.0.0:53588 *:*
UDP 0.0.0.0:53589 *:*
UDP 0.0.0.0:53590 *:*
UDP 0.0.0.0:53591 *:*
UDP 0.0.0.0:53592 *:*
UDP 0.0.0.0:53593 *:*
UDP 0.0.0.0:53594 *:*
UDP 0.0.0.0:53595 *:*
UDP 0.0.0.0:53596 *:*
UDP 0.0.0.0:53597 *:*
UDP 0.0.0.0:53598 *:*
UDP 0.0.0.0:53599 *:*
UDP 0.0.0.0:53600 *:*
UDP 0.0.0.0:53601 *:*
UDP 0.0.0.0:53602 *:*
UDP 0.0.0.0:53603 *:*
UDP 0.0.0.0:53604 *:*
UDP 0.0.0.0:53605 *:*
UDP 0.0.0.0:53606 *:*
UDP 0.0.0.0:53607 *:*
UDP 0.0.0.0:53608 *:*
UDP 0.0.0.0:53609 *:*
UDP 0.0.0.0:53610 *:*
UDP 0.0.0.0:53611 *:*
UDP 0.0.0.0:53612 *:*
UDP 0.0.0.0:53613 *:*
UDP 0.0.0.0:53614 *:*
UDP 0.0.0.0:53615 *:*
UDP 0.0.0.0:53616 *:*
UDP 0.0.0.0:53617 *:*
UDP 0.0.0.0:53618 *:*
UDP 0.0.0.0:53619 *:*
UDP 0.0.0.0:53620 *:*
UDP 0.0.0.0:53621 *:*
UDP 0.0.0.0:53622 *:*
UDP 0.0.0.0:53623 *:*
UDP 0.0.0.0:53624 *:*
UDP 0.0.0.0:53625 *:*
UDP 0.0.0.0:53626 *:*
UDP 0.0.0.0:53627 *:*
UDP 0.0.0.0:53628 *:*
UDP 0.0.0.0:53629 *:*
UDP 0.0.0.0:53630 *:*
UDP 0.0.0.0:53631 *:*
UDP 0.0.0.0:53632 *:*
UDP 0.0.0.0:53633 *:*
UDP 0.0.0.0:53634 *:*
UDP 0.0.0.0:53635 *:*
UDP 0.0.0.0:53636 *:*
UDP 0.0.0.0:53637 *:*
UDP 0.0.0.0:53638 *:*
UDP 0.0.0.0:53639 *:*
UDP 0.0.0.0:53640 *:*
UDP 0.0.0.0:53641 *:*
UDP 0.0.0.0:53642 *:*
UDP 0.0.0.0:53643 *:*
UDP 0.0.0.0:53644 *:*
UDP 0.0.0.0:53645 *:*
UDP 0.0.0.0:53646 *:*
UDP 0.0.0.0:53647 *:*
UDP 0.0.0.0:53648 *:*
UDP 0.0.0.0:53649 *:*
UDP 0.0.0.0:53650 *:*
UDP 0.0.0.0:53651 *:*
UDP 0.0.0.0:53652 *:*
UDP 0.0.0.0:53653 *:*
UDP 0.0.0.0:53654 *:*
UDP 0.0.0.0:53655 *:*
UDP 0.0.0.0:53656 *:*
UDP 0.0.0.0:53657 *:*
UDP 0.0.0.0:53658 *:*
UDP 0.0.0.0:53659 *:*
UDP 0.0.0.0:53660 *:*
UDP 0.0.0.0:53661 *:*
UDP 0.0.0.0:53662 *:*
UDP 0.0.0.0:53663 *:*
UDP 0.0.0.0:53664 *:*
UDP 0.0.0.0:53665 *:*
UDP 0.0.0.0:53666 *:*
UDP 0.0.0.0:53667 *:*
UDP 0.0.0.0:53668 *:*
UDP 0.0.0.0:53669 *:*
UDP 0.0.0.0:53670 *:*
UDP 0.0.0.0:53671 *:*
UDP 0.0.0.0:53672 *:*
UDP 0.0.0.0:53673 *:*
UDP 0.0.0.0:53674 *:*
UDP 0.0.0.0:53675 *:*
UDP 0.0.0.0:53676 *:*
UDP 0.0.0.0:53677 *:*
UDP 0.0.0.0:53678 *:*
UDP 0.0.0.0:53679 *:*
UDP 0.0.0.0:53680 *:*
UDP 0.0.0.0:53681 *:*
UDP 0.0.0.0:53682 *:*
UDP 0.0.0.0:53683 *:*
UDP 0.0.0.0:53684 *:*
UDP 0.0.0.0:53685 *:*
UDP 0.0.0.0:53686 *:*
UDP 0.0.0.0:53687 *:*
UDP 0.0.0.0:53688 *:*
UDP 0.0.0.0:53689 *:*
UDP 0.0.0.0:53690 *:*
UDP 0.0.0.0:53691 *:*
UDP 0.0.0.0:53692 *:*
UDP 0.0.0.0:53693 *:*
UDP 0.0.0.0:53694 *:*
UDP 0.0.0.0:53695 *:*
UDP 0.0.0.0:53696 *:*
UDP 0.0.0.0:53697 *:*
UDP 0.0.0.0:53698 *:*
UDP 0.0.0.0:53699 *:*
UDP 0.0.0.0:53700 *:*
UDP 0.0.0.0:53701 *:*
UDP 0.0.0.0:53702 *:*
UDP 0.0.0.0:53703 *:*
UDP 0.0.0.0:53704 *:*
UDP 0.0.0.0:53705 *:*
UDP 0.0.0.0:53706 *:*
UDP 0.0.0.0:53707 *:*
UDP 0.0.0.0:53708 *:*
UDP 0.0.0.0:53709 *:*
UDP 0.0.0.0:53710 *:*
UDP 0.0.0.0:53711 *:*
UDP 0.0.0.0:53712 *:*
UDP 0.0.0.0:53713 *:*
UDP 0.0.0.0:53714 *:*
UDP 0.0.0.0:53715 *:*
UDP 0.0.0.0:53716 *:*
UDP 0.0.0.0:53717 *:*
UDP 0.0.0.0:53718 *:*
UDP 0.0.0.0:53719 *:*
UDP 0.0.0.0:53720 *:*
UDP 0.0.0.0:53721 *:*
UDP 0.0.0.0:53722 *:*
UDP 0.0.0.0:53723 *:*
UDP 0.0.0.0:53724 *:*
UDP 0.0.0.0:53725 *:*
UDP 0.0.0.0:53726 *:*
UDP 0.0.0.0:53727 *:*
UDP 0.0.0.0:53728 *:*
UDP 0.0.0.0:53729 *:*
UDP 0.0.0.0:53730 *:*
UDP 0.0.0.0:53731 *:*
UDP 0.0.0.0:53732 *:*
UDP 0.0.0.0:53733 *:*
UDP 0.0.0.0:53734 *:*
UDP 0.0.0.0:53735 *:*
UDP 0.0.0.0:53736 *:*
UDP 0.0.0.0:53737 *:*
UDP 0.0.0.0:53738 *:*
UDP 0.0.0.0:53739 *:*
UDP 0.0.0.0:53740 *:*
UDP 0.0.0.0:53741 *:*
UDP 0.0.0.0:53742 *:*
UDP 0.0.0.0:53743 *:*
UDP 0.0.0.0:53744 *:*
UDP 0.0.0.0:53745 *:*
UDP 0.0.0.0:53746 *:*
UDP 0.0.0.0:53747 *:*
UDP 0.0.0.0:53748 *:*
UDP 0.0.0.0:53749 *:*
UDP 0.0.0.0:53750 *:*
UDP 0.0.0.0:53751 *:*
UDP 0.0.0.0:53752 *:*
UDP 0.0.0.0:53753 *:*
UDP 0.0.0.0:53754 *:*
UDP 0.0.0.0:53755 *:*
UDP 0.0.0.0:53756 *:*
UDP 0.0.0.0:53757 *:*
UDP 0.0.0.0:53758 *:*
UDP 0.0.0.0:53759 *:*
UDP 0.0.0.0:53760 *:*
UDP 0.0.0.0:53761 *:*
UDP 0.0.0.0:53762 *:*
UDP 0.0.0.0:53763 *:*
UDP 0.0.0.0:53764 *:*
UDP 0.0.0.0:53765 *:*
UDP 0.0.0.0:53766 *:*
UDP 0.0.0.0:53767 *:*
UDP 0.0.0.0:53768 *:*
UDP 0.0.0.0:53769 *:*
UDP 0.0.0.0:53770 *:*
UDP 0.0.0.0:53771 *:*
UDP 0.0.0.0:53772 *:*
UDP 0.0.0.0:53773 *:*
UDP 0.0.0.0:53774 *:*
UDP 0.0.0.0:53775 *:*
UDP 0.0.0.0:53776 *:*
UDP 0.0.0.0:53777 *:*
UDP 0.0.0.0:53778 *:*
UDP 0.0.0.0:53779 *:*
UDP 0.0.0.0:53780 *:*
UDP 0.0.0.0:53781 *:*
UDP 0.0.0.0:53782 *:*
UDP 0.0.0.0:53783 *:*
UDP 0.0.0.0:53784 *:*
UDP 0.0.0.0:53785 *:*
UDP 0.0.0.0:53786 *:*
UDP 0.0.0.0:53787 *:*
UDP 0.0.0.0:53788 *:*
UDP 0.0.0.0:53789 *:*
UDP 0.0.0.0:53790 *:*
UDP 0.0.0.0:53791 *:*
UDP 0.0.0.0:53792 *:*
UDP 0.0.0.0:53793 *:*
UDP 0.0.0.0:53794 *:*
UDP 0.0.0.0:53795 *:*
UDP 0.0.0.0:53796 *:*
UDP 0.0.0.0:53797 *:*
UDP 0.0.0.0:53798 *:*
UDP 0.0.0.0:53799 *:*
UDP 0.0.0.0:53800 *:*
UDP 0.0.0.0:53801 *:*
UDP 0.0.0.0:53802 *:*
UDP 0.0.0.0:53803 *:*
UDP 0.0.0.0:53804 *:*
UDP 0.0.0.0:53805 *:*
UDP 0.0.0.0:53806 *:*
UDP 0.0.0.0:53807 *:*
UDP 0.0.0.0:53808 *:*
UDP 0.0.0.0:53809 *:*
UDP 0.0.0.0:53810 *:*
UDP 0.0.0.0:53811 *:*
UDP 0.0.0.0:53812 *:*
UDP 0.0.0.0:53813 *:*
UDP 0.0.0.0:53814 *:*
UDP 0.0.0.0:53815 *:*
UDP 0.0.0.0:53816 *:*
UDP 0.0.0.0:53817 *:*
UDP 0.0.0.0:53818 *:*
UDP 0.0.0.0:53819 *:*
UDP 0.0.0.0:53820 *:*
UDP 0.0.0.0:53821 *:*
UDP 0.0.0.0:53822 *:*
UDP 0.0.0.0:53823 *:*
UDP 0.0.0.0:53824 *:*
UDP 0.0.0.0:53825 *:*
UDP 0.0.0.0:53826 *:*
UDP 0.0.0.0:53827 *:*
UDP 0.0.0.0:53828 *:*
UDP 0.0.0.0:53829 *:*
UDP 0.0.0.0:53830 *:*
UDP 0.0.0.0:53831 *:*
UDP 0.0.0.0:53832 *:*
UDP 0.0.0.0:53833 *:*
UDP 0.0.0.0:53834 *:*
UDP 0.0.0.0:53835 *:*
UDP 0.0.0.0:53836 *:*
UDP 0.0.0.0:53837 *:*
UDP 0.0.0.0:53838 *:*
UDP 0.0.0.0:53839 *:*
UDP 0.0.0.0:53840 *:*
UDP 0.0.0.0:53841 *:*
UDP 0.0.0.0:53842 *:*
UDP 0.0.0.0:53843 *:*
UDP 0.0.0.0:53844 *:*
UDP 0.0.0.0:53845 *:*
UDP 0.0.0.0:53846 *:*
UDP 0.0.0.0:53847 *:*
UDP 0.0.0.0:53848 *:*
UDP 0.0.0.0:53849 *:*
UDP 0.0.0.0:53850 *:*
UDP 0.0.0.0:53851 *:*
UDP 0.0.0.0:53852 *:*
UDP 0.0.0.0:53853 *:*
UDP 0.0.0.0:53854 *:*
UDP 0.0.0.0:53855 *:*
UDP 0.0.0.0:53856 *:*
UDP 0.0.0.0:53857 *:*
UDP 0.0.0.0:53858 *:*
UDP 0.0.0.0:53859 *:*
UDP 0.0.0.0:53860 *:*
UDP 0.0.0.0:53861 *:*
UDP 0.0.0.0:53862 *:*
UDP 0.0.0.0:53863 *:*
UDP 0.0.0.0:53864 *:*
UDP 0.0.0.0:53865 *:*
UDP 0.0.0.0:53866 *:*
UDP 0.0.0.0:53867 *:*
UDP 0.0.0.0:53868 *:*
UDP 0.0.0.0:53869 *:*
UDP 0.0.0.0:53870 *:*
UDP 0.0.0.0:53871 *:*
UDP 0.0.0.0:53872 *:*
UDP 0.0.0.0:53873 *:*
UDP 0.0.0.0:53874 *:*
UDP 0.0.0.0:53875 *:*
UDP 0.0.0.0:53876 *:*
UDP 0.0.0.0:53877 *:*
UDP 0.0.0.0:53878 *:*
UDP 0.0.0.0:53879 *:*
UDP 0.0.0.0:53880 *:*
UDP 0.0.0.0:53881 *:*
UDP 0.0.0.0:53882 *:*
UDP 0.0.0.0:53883 *:*
UDP 0.0.0.0:53884 *:*
UDP 0.0.0.0:53885 *:*
UDP 0.0.0.0:53886 *:*
UDP 0.0.0.0:53887 *:*
UDP 0.0.0.0:53888 *:*
UDP 0.0.0.0:53889 *:*
UDP 0.0.0.0:53890 *:*
UDP 0.0.0.0:53891 *:*
UDP 0.0.0.0:53892 *:*
UDP 0.0.0.0:53893 *:*
UDP 0.0.0.0:53894 *:*
UDP 0.0.0.0:53895 *:*
UDP 0.0.0.0:53896 *:*
UDP 0.0.0.0:53897 *:*
UDP 0.0.0.0:53898 *:*
UDP 0.0.0.0:53899 *:*
UDP 0.0.0.0:53900 *:*
UDP 0.0.0.0:53901 *:*
UDP 0.0.0.0:53902 *:*
UDP 0.0.0.0:53903 *:*
UDP 0.0.0.0:53904 *:*
UDP 0.0.0.0:53905 *:*
UDP 0.0.0.0:53906 *:*
UDP 0.0.0.0:53907 *:*
UDP 0.0.0.0:53908 *:*
UDP 0.0.0.0:53909 *:*
UDP 0.0.0.0:53910 *:*
UDP 0.0.0.0:53911 *:*
UDP 0.0.0.0:53912 *:*
UDP 0.0.0.0:53913 *:*
UDP 0.0.0.0:53914 *:*
UDP 0.0.0.0:53915 *:*
UDP 0.0.0.0:53916 *:*
UDP 0.0.0.0:53917 *:*
UDP 0.0.0.0:53918 *:*
UDP 0.0.0.0:53919 *:*
UDP 0.0.0.0:53920 *:*
UDP 0.0.0.0:53921 *:*
UDP 0.0.0.0:53922 *:*
UDP 0.0.0.0:53923 *:*
UDP 0.0.0.0:53924 *:*
UDP 0.0.0.0:53925 *:*
UDP 0.0.0.0:53926 *:*
UDP 0.0.0.0:53927 *:*
UDP 0.0.0.0:53928 *:*
UDP 0.0.0.0:53929 *:*
UDP 0.0.0.0:53930 *:*
UDP 0.0.0.0:53931 *:*
UDP 0.0.0.0:53932 *:*
UDP 0.0.0.0:53933 *:*
UDP 0.0.0.0:53934 *:*
UDP 0.0.0.0:53935 *:*
UDP 0.0.0.0:53936 *:*
UDP 0.0.0.0:53937 *:*
UDP 0.0.0.0:53938 *:*
UDP 0.0.0.0:53939 *:*
UDP 0.0.0.0:53940 *:*
UDP 0.0.0.0:53941 *:*
UDP 0.0.0.0:53942 *:*
UDP 0.0.0.0:53943 *:*
UDP 0.0.0.0:53944 *:*
UDP 0.0.0.0:53945 *:*
UDP 0.0.0.0:53946 *:*
UDP 0.0.0.0:53947 *:*
UDP 0.0.0.0:53948 *:*
UDP 0.0.0.0:53949 *:*
UDP 0.0.0.0:53950 *:*
UDP 0.0.0.0:53951 *:*
UDP 0.0.0.0:53952 *:*
UDP 0.0.0.0:53953 *:*
UDP 0.0.0.0:53954 *:*
UDP 0.0.0.0:53955 *:*
UDP 0.0.0.0:53956 *:*
UDP 0.0.0.0:53957 *:*
UDP 0.0.0.0:53958 *:*
UDP 0.0.0.0:53959 *:*
UDP 0.0.0.0:53960 *:*
UDP 0.0.0.0:53961 *:*
UDP 0.0.0.0:53962 *:*
UDP 0.0.0.0:53963 *:*
UDP 0.0.0.0:53964 *:*
UDP 0.0.0.0:53965 *:*
UDP 0.0.0.0:53966 *:*
UDP 0.0.0.0:53967 *:*
UDP 0.0.0.0:53968 *:*
UDP 0.0.0.0:53969 *:*
UDP 0.0.0.0:53970 *:*
UDP 0.0.0.0:53971 *:*
UDP 0.0.0.0:53972 *:*
UDP 0.0.0.0:53973 *:*
UDP 0.0.0.0:53974 *:*
UDP 0.0.0.0:53975 *:*
UDP 0.0.0.0:53976 *:*
UDP 0.0.0.0:53977 *:*
UDP 0.0.0.0:53978 *:*
UDP 0.0.0.0:53979 *:*
UDP 0.0.0.0:53980 *:*
UDP 0.0.0.0:53981 *:*
UDP 0.0.0.0:53982 *:*
UDP 0.0.0.0:53983 *:*
UDP 0.0.0.0:53984 *:*
UDP 0.0.0.0:53985 *:*
UDP 0.0.0.0:53986 *:*
UDP 0.0.0.0:53987 *:*
UDP 0.0.0.0:53988 *:*
UDP 0.0.0.0:53989 *:*
UDP 0.0.0.0:53990 *:*
UDP 0.0.0.0:53991 *:*
UDP 0.0.0.0:53992 *:*
UDP 0.0.0.0:53993 *:*
UDP 0.0.0.0:53994 *:*
UDP 0.0.0.0:53995 *:*
UDP 0.0.0.0:53996 *:*
UDP 0.0.0.0:53997 *:*
UDP 0.0.0.0:53998 *:*
UDP 0.0.0.0:53999 *:*
UDP 0.0.0.0:54000 *:*
UDP 0.0.0.0:54001 *:*
UDP 0.0.0.0:54002 *:*
UDP 0.0.0.0:54003 *:*
UDP 0.0.0.0:54004 *:*
UDP 0.0.0.0:54005 *:*
UDP 0.0.0.0:54006 *:*
UDP 0.0.0.0:54007 *:*
UDP 0.0.0.0:54008 *:*
UDP 0.0.0.0:54009 *:*
UDP 0.0.0.0:54010 *:*
UDP 0.0.0.0:54011 *:*
UDP 0.0.0.0:54012 *:*
UDP 0.0.0.0:54013 *:*
UDP 0.0.0.0:54014 *:*
UDP 0.0.0.0:54015 *:*
UDP 0.0.0.0:54016 *:*
UDP 0.0.0.0:54017 *:*
UDP 0.0.0.0:54018 *:*
UDP 0.0.0.0:54019 *:*
UDP 0.0.0.0:54020 *:*
UDP 0.0.0.0:54021 *:*
UDP 0.0.0.0:54022 *:*
UDP 0.0.0.0:54023 *:*
UDP 0.0.0.0:54024 *:*
UDP 0.0.0.0:54025 *:*
UDP 0.0.0.0:54026 *:*
UDP 0.0.0.0:54027 *:*
UDP 0.0.0.0:54028 *:*
UDP 0.0.0.0:54029 *:*
UDP 0.0.0.0:54030 *:*
UDP 0.0.0.0:54031 *:*
UDP 0.0.0.0:54032 *:*
UDP 0.0.0.0:54033 *:*
UDP 0.0.0.0:54034 *:*
UDP 0.0.0.0:54035 *:*
UDP 0.0.0.0:54036 *:*
UDP 0.0.0.0:54037 *:*
UDP 0.0.0.0:54038 *:*
UDP 0.0.0.0:54039 *:*
UDP 0.0.0.0:54040 *:*
UDP 0.0.0.0:54041 *:*
UDP 0.0.0.0:54042 *:*
UDP 0.0.0.0:54043 *:*
UDP 0.0.0.0:54044 *:*
UDP 0.0.0.0:54045 *:*
UDP 0.0.0.0:54046 *:*
UDP 0.0.0.0:54047 *:*
UDP 0.0.0.0:54048 *:*
UDP 0.0.0.0:54049 *:*
UDP 0.0.0.0:54050 *:*
UDP 0.0.0.0:54051 *:*
UDP 0.0.0.0:54052 *:*
UDP 0.0.0.0:54053 *:*
UDP 0.0.0.0:54054 *:*
UDP 0.0.0.0:54055 *:*
UDP 0.0.0.0:54056 *:*
UDP 0.0.0.0:54057 *:*
UDP 0.0.0.0:54058 *:*
UDP 0.0.0.0:54059 *:*
UDP 0.0.0.0:54060 *:*
UDP 0.0.0.0:54061 *:*
UDP 0.0.0.0:54062 *:*
UDP 0.0.0.0:54063 *:*
UDP 0.0.0.0:54064 *:*
UDP 0.0.0.0:54065 *:*
UDP 0.0.0.0:54066 *:*
UDP 0.0.0.0:54067 *:*
UDP 0.0.0.0:54068 *:*
UDP 0.0.0.0:54069 *:*
UDP 0.0.0.0:54070 *:*
UDP 0.0.0.0:54071 *:*
UDP 0.0.0.0:54072 *:*
UDP 0.0.0.0:54073 *:*
UDP 0.0.0.0:54074 *:*
UDP 0.0.0.0:54075 *:*
UDP 0.0.0.0:54076 *:*
UDP 0.0.0.0:54077 *:*
UDP 0.0.0.0:54078 *:*
UDP 0.0.0.0:54079 *:*
UDP 0.0.0.0:54080 *:*
UDP 0.0.0.0:54081 *:*
UDP 0.0.0.0:54082 *:*
UDP 0.0.0.0:54083 *:*
UDP 0.0.0.0:54084 *:*
UDP 0.0.0.0:54085 *:*
UDP 0.0.0.0:54086 *:*
UDP 0.0.0.0:54087 *:*
UDP 0.0.0.0:54088 *:*
UDP 0.0.0.0:54089 *:*
UDP 0.0.0.0:54090 *:*
UDP 0.0.0.0:54091 *:*
UDP 0.0.0.0:54092 *:*
UDP 0.0.0.0:54093 *:*
UDP 0.0.0.0:54094 *:*
UDP 0.0.0.0:54095 *:*
UDP 0.0.0.0:54096 *:*
UDP 0.0.0.0:54097 *:*
UDP 0.0.0.0:54098 *:*
UDP 0.0.0.0:54099 *:*
UDP 0.0.0.0:54100 *:*
UDP 0.0.0.0:54101 *:*
UDP 0.0.0.0:54102 *:*
UDP 0.0.0.0:54103 *:*
UDP 0.0.0.0:54104 *:*
UDP 0.0.0.0:54105 *:*
UDP 0.0.0.0:54106 *:*
UDP 0.0.0.0:54107 *:*
UDP 0.0.0.0:54108 *:*
UDP 0.0.0.0:54109 *:*
UDP 0.0.0.0:54110 *:*
UDP 0.0.0.0:54111 *:*
UDP 0.0.0.0:54112 *:*
UDP 0.0.0.0:54113 *:*
UDP 0.0.0.0:54114 *:*
UDP 0.0.0.0:54115 *:*
UDP 0.0.0.0:54116 *:*
UDP 0.0.0.0:54117 *:*
UDP 0.0.0.0:54118 *:*
UDP 0.0.0.0:54119 *:*
UDP 0.0.0.0:54120 *:*
UDP 0.0.0.0:54121 *:*
UDP 0.0.0.0:54122 *:*
UDP 0.0.0.0:54123 *:*
UDP 0.0.0.0:54124 *:*
UDP 0.0.0.0:54125 *:*
UDP 0.0.0.0:54126 *:*
UDP 0.0.0.0:54127 *:*
UDP 0.0.0.0:54128 *:*
UDP 0.0.0.0:54129 *:*
UDP 0.0.0.0:54130 *:*
UDP 0.0.0.0:54131 *:*
UDP 0.0.0.0:54132 *:*
UDP 0.0.0.0:54133 *:*
UDP 0.0.0.0:54134 *:*
UDP 0.0.0.0:54135 *:*
UDP 0.0.0.0:54136 *:*
UDP 0.0.0.0:54137 *:*
UDP 0.0.0.0:54138 *:*
UDP 0.0.0.0:54139 *:*
UDP 0.0.0.0:54140 *:*
UDP 0.0.0.0:54141 *:*
UDP 0.0.0.0:54142 *:*
UDP 0.0.0.0:54143 *:*
UDP 0.0.0.0:54144 *:*
UDP 0.0.0.0:54145 *:*
UDP 0.0.0.0:54146 *:*
UDP 0.0.0.0:54147 *:*
UDP 0.0.0.0:54148 *:*
UDP 0.0.0.0:54149 *:*
UDP 0.0.0.0:54150 *:*
UDP 0.0.0.0:54151 *:*
UDP 0.0.0.0:54152 *:*
UDP 0.0.0.0:54153 *:*
UDP 0.0.0.0:54154 *:*
UDP 0.0.0.0:54155 *:*
UDP 0.0.0.0:54156 *:*
UDP 0.0.0.0:54157 *:*
UDP 0.0.0.0:54158 *:*
UDP 0.0.0.0:54159 *:*
UDP 0.0.0.0:54160 *:*
UDP 0.0.0.0:54161 *:*
UDP 0.0.0.0:54162 *:*
UDP 0.0.0.0:54163 *:*
UDP 0.0.0.0:54164 *:*
UDP 0.0.0.0:54165 *:*
UDP 0.0.0.0:54166 *:*
UDP 0.0.0.0:54167 *:*
UDP 0.0.0.0:54168 *:*
UDP 0.0.0.0:54169 *:*
UDP 0.0.0.0:54170 *:*
UDP 0.0.0.0:54171 *:*
UDP 0.0.0.0:54172 *:*
UDP 0.0.0.0:54173 *:*
UDP 0.0.0.0:54174 *:*
UDP 0.0.0.0:54175 *:*
UDP 0.0.0.0:54176 *:*
UDP 0.0.0.0:54177 *:*
UDP 0.0.0.0:54178 *:*
UDP 0.0.0.0:54179 *:*
UDP 0.0.0.0:54180 *:*
UDP 0.0.0.0:54181 *:*
UDP 0.0.0.0:54182 *:*
UDP 0.0.0.0:54183 *:*
UDP 0.0.0.0:54184 *:*
UDP 0.0.0.0:54185 *:*
UDP 0.0.0.0:54186 *:*
UDP 0.0.0.0:54187 *:*
UDP 0.0.0.0:54188 *:*
UDP 0.0.0.0:54189 *:*
UDP 0.0.0.0:54190 *:*
UDP 0.0.0.0:54191 *:*
UDP 0.0.0.0:54192 *:*
UDP 0.0.0.0:54193 *:*
UDP 0.0.0.0:54194 *:*
UDP 0.0.0.0:54195 *:*
UDP 0.0.0.0:54196 *:*
UDP 0.0.0.0:54197 *:*
UDP 0.0.0.0:54198 *:*
UDP 0.0.0.0:54199 *:*
UDP 0.0.0.0:54200 *:*
UDP 0.0.0.0:54201 *:*
UDP 0.0.0.0:54202 *:*
UDP 0.0.0.0:54203 *:*
UDP 0.0.0.0:54204 *:*
UDP 0.0.0.0:54205 *:*
UDP 0.0.0.0:54206 *:*
UDP 0.0.0.0:54207 *:*
UDP 0.0.0.0:54208 *:*
UDP 0.0.0.0:54209 *:*
UDP 0.0.0.0:54210 *:*
UDP 0.0.0.0:54211 *:*
UDP 0.0.0.0:54212 *:*
UDP 0.0.0.0:54213 *:*
UDP 0.0.0.0:54214 *:*
UDP 0.0.0.0:54215 *:*
UDP 0.0.0.0:54216 *:*
UDP 0.0.0.0:54217 *:*
UDP 0.0.0.0:54218 *:*
UDP 0.0.0.0:54219 *:*
UDP 0.0.0.0:54220 *:*
UDP 0.0.0.0:54221 *:*
UDP 0.0.0.0:54222 *:*
UDP 0.0.0.0:54223 *:*
UDP 0.0.0.0:54224 *:*
UDP 0.0.0.0:54225 *:*
UDP 0.0.0.0:54226 *:*
UDP 0.0.0.0:54227 *:*
UDP 0.0.0.0:54228 *:*
UDP 0.0.0.0:54229 *:*
UDP 0.0.0.0:54230 *:*
UDP 0.0.0.0:54231 *:*
UDP 0.0.0.0:54232 *:*
UDP 0.0.0.0:54233 *:*
UDP 0.0.0.0:54234 *:*
UDP 0.0.0.0:54235 *:*
UDP 0.0.0.0:54236 *:*
UDP 0.0.0.0:54237 *:*
UDP 0.0.0.0:54238 *:*
UDP 0.0.0.0:54239 *:*
UDP 0.0.0.0:54240 *:*
UDP 0.0.0.0:54241 *:*
UDP 0.0.0.0:54242 *:*
UDP 0.0.0.0:54243 *:*
UDP 0.0.0.0:54244 *:*
UDP 0.0.0.0:54245 *:*
UDP 0.0.0.0:54246 *:*
UDP 0.0.0.0:54247 *:*
UDP 0.0.0.0:54248 *:*
UDP 0.0.0.0:54249 *:*
UDP 0.0.0.0:54250 *:*
UDP 0.0.0.0:54251 *:*
UDP 0.0.0.0:54252 *:*
UDP 0.0.0.0:54253 *:*
UDP 0.0.0.0:54254 *:*
UDP 0.0.0.0:54255 *:*
UDP 0.0.0.0:54256 *:*
UDP 0.0.0.0:54257 *:*
UDP 0.0.0.0:54258 *:*
UDP 0.0.0.0:54259 *:*
UDP 0.0.0.0:54260 *:*
UDP 0.0.0.0:54261 *:*
UDP 0.0.0.0:54262 *:*
UDP 0.0.0.0:54263 *:*
UDP 0.0.0.0:54264 *:*
UDP 0.0.0.0:54265 *:*
UDP 0.0.0.0:54266 *:*
UDP 0.0.0.0:54267 *:*
UDP 0.0.0.0:54268 *:*
UDP 0.0.0.0:54269 *:*
UDP 0.0.0.0:54270 *:*
UDP 0.0.0.0:54271 *:*
UDP 0.0.0.0:54272 *:*
UDP 0.0.0.0:54273 *:*
UDP 0.0.0.0:54274 *:*
UDP 0.0.0.0:54275 *:*
UDP 0.0.0.0:54276 *:*
UDP 0.0.0.0:54277 *:*
UDP 0.0.0.0:54278 *:*
UDP 0.0.0.0:54279 *:*
UDP 0.0.0.0:54280 *:*
UDP 0.0.0.0:54281 *:*
UDP 0.0.0.0:54282 *:*
UDP 0.0.0.0:54283 *:*
UDP 0.0.0.0:54284 *:*
UDP 0.0.0.0:54285 *:*
UDP 0.0.0.0:54286 *:*
UDP 0.0.0.0:54287 *:*
UDP 0.0.0.0:54288 *:*
UDP 0.0.0.0:54289 *:*
UDP 0.0.0.0:54290 *:*
UDP 0.0.0.0:54291 *:*
UDP 0.0.0.0:54292 *:*
UDP 0.0.0.0:54293 *:*
UDP 0.0.0.0:54294 *:*
UDP 0.0.0.0:54295 *:*
UDP 0.0.0.0:54296 *:*
UDP 0.0.0.0:54297 *:*
UDP 0.0.0.0:54298 *:*
UDP 0.0.0.0:54299 *:*
UDP 0.0.0.0:54300 *:*
UDP 0.0.0.0:54301 *:*
UDP 0.0.0.0:54302 *:*
UDP 0.0.0.0:54303 *:*
UDP 0.0.0.0:54304 *:*
UDP 0.0.0.0:54305 *:*
UDP 0.0.0.0:54306 *:*
UDP 0.0.0.0:54307 *:*
UDP 0.0.0.0:54308 *:*
UDP 0.0.0.0:54309 *:*
UDP 0.0.0.0:54310 *:*
UDP 0.0.0.0:54311 *:*
UDP 0.0.0.0:54312 *:*
UDP 0.0.0.0:54313 *:*
UDP 0.0.0.0:54314 *:*
UDP 0.0.0.0:54315 *:*
UDP 0.0.0.0:54316 *:*
UDP 0.0.0.0:54317 *:*
UDP 0.0.0.0:54318 *:*
UDP 0.0.0.0:54319 *:*
UDP 0.0.0.0:54320 *:*
UDP 0.0.0.0:54321 *:*
UDP 0.0.0.0:54322 *:*
UDP 0.0.0.0:54323 *:*
UDP 0.0.0.0:54324 *:*
UDP 0.0.0.0:54325 *:*
UDP 0.0.0.0:54326 *:*
UDP 0.0.0.0:54327 *:*
UDP 0.0.0.0:54328 *:*
UDP 0.0.0.0:54329 *:*
UDP 0.0.0.0:54330 *:*
UDP 0.0.0.0:54331 *:*
UDP 0.0.0.0:54332 *:*
UDP 0.0.0.0:54333 *:*
UDP 0.0.0.0:54334 *:*
UDP 0.0.0.0:54335 *:*
UDP 0.0.0.0:54336 *:*
UDP 0.0.0.0:54337 *:*
UDP 0.0.0.0:54338 *:*
UDP 0.0.0.0:54339 *:*
UDP 0.0.0.0:54340 *:*
UDP 0.0.0.0:54341 *:*
UDP 0.0.0.0:54342 *:*
UDP 0.0.0.0:54343 *:*
UDP 0.0.0.0:54344 *:*
UDP 0.0.0.0:54345 *:*
UDP 0.0.0.0:54346 *:*
UDP 0.0.0.0:54347 *:*
UDP 0.0.0.0:54348 *:*
UDP 0.0.0.0:54349 *:*
UDP 0.0.0.0:54350 *:*
UDP 0.0.0.0:54351 *:*
UDP 0.0.0.0:54352 *:*
UDP 0.0.0.0:54353 *:*
UDP 0.0.0.0:54354 *:*
UDP 0.0.0.0:54355 *:*
UDP 0.0.0.0:54356 *:*
UDP 0.0.0.0:54357 *:*
UDP 0.0.0.0:54358 *:*
UDP 0.0.0.0:54359 *:*
UDP 0.0.0.0:54360 *:*
UDP 0.0.0.0:54361 *:*
UDP 0.0.0.0:54362 *:*
UDP 0.0.0.0:54363 *:*
UDP 0.0.0.0:54364 *:*
UDP 0.0.0.0:54365 *:*
UDP 0.0.0.0:54366 *:*
UDP 0.0.0.0:54367 *:*
UDP 0.0.0.0:54368 *:*
UDP 0.0.0.0:54369 *:*
UDP 0.0.0.0:54370 *:*
UDP 0.0.0.0:54371 *:*
UDP 0.0.0.0:54372 *:*
UDP 0.0.0.0:54373 *:*
UDP 0.0.0.0:54374 *:*
UDP 0.0.0.0:54375 *:*
UDP 0.0.0.0:54376 *:*
UDP 0.0.0.0:54377 *:*
UDP 0.0.0.0:54378 *:*
UDP 0.0.0.0:54379 *:*
UDP 0.0.0.0:54380 *:*
UDP 0.0.0.0:54381 *:*
UDP 0.0.0.0:54382 *:*
UDP 0.0.0.0:54383 *:*
UDP 0.0.0.0:54384 *:*
UDP 0.0.0.0:54385 *:*
UDP 0.0.0.0:54386 *:*
UDP 0.0.0.0:54387 *:*
UDP 0.0.0.0:54388 *:*
UDP 0.0.0.0:54389 *:*
UDP 0.0.0.0:54390 *:*
UDP 0.0.0.0:54391 *:*
UDP 0.0.0.0:54392 *:*
UDP 0.0.0.0:54393 *:*
UDP 0.0.0.0:54394 *:*
UDP 0.0.0.0:54395 *:*
UDP 0.0.0.0:54396 *:*
UDP 0.0.0.0:54397 *:*
UDP 0.0.0.0:54398 *:*
UDP 0.0.0.0:54399 *:*
UDP 0.0.0.0:54400 *:*
UDP 0.0.0.0:54401 *:*
UDP 0.0.0.0:54402 *:*
UDP 0.0.0.0:54403 *:*
UDP 0.0.0.0:54404 *:*
UDP 0.0.0.0:54405 *:*
UDP 0.0.0.0:54406 *:*
UDP 0.0.0.0:54407 *:*
UDP 0.0.0.0:54408 *:*
UDP 0.0.0.0:54409 *:*
UDP 0.0.0.0:54410 *:*
UDP 0.0.0.0:54411 *:*
UDP 0.0.0.0:54412 *:*
UDP 0.0.0.0:54413 *:*
UDP 0.0.0.0:54414 *:*
UDP 0.0.0.0:54415 *:*
UDP 0.0.0.0:54416 *:*
UDP 0.0.0.0:54417 *:*
UDP 0.0.0.0:54418 *:*
UDP 0.0.0.0:54419 *:*
UDP 0.0.0.0:54420 *:*
UDP 0.0.0.0:59168 *:*
UDP 127.0.0.1:53 *:*
UDP 127.0.0.1:51917 *:*
UDP 127.0.0.1:54422 *:*
UDP 127.0.0.1:55885 *:*
UDP 127.0.0.1:57290 *:*
UDP 127.0.0.1:57366 *:*
UDP 127.0.0.1:57440 *:*
UDP 127.0.0.1:57918 *:*
UDP 127.0.0.1:61361 *:*
UDP 127.0.0.1:61750 *:*
UDP 127.0.0.1:65152 *:*
UDP 192.168.202.77:53 *:*
UDP 192.168.202.77:88 *:*
UDP 192.168.202.77:137 *:*
UDP 192.168.202.77:138 *:*
UDP 192.168.202.77:464 *:*
UDP [::]:123 *:*
UDP [::]:3389 *:*
UDP [::]:59169 *:*
UDP [::1]:53 *:*
UDP [::1]:51918 *:*
I'm trying to connect through the Nagios XI server with the IP address 192.168.201.2
IP ping is working from Nagios server to AD server and vice versa.
Attached the AD as well as LDAP settings above when I add the server on the Nagios XI.
UDP [::]:123 *:*
UDP [::]:3389 *:*
UDP [::]:59169 *:*
UDP [::1]:53 *:*
UDP [::1]:51918 *:*
Re: Authentication issue on Importing contacts from AD
The netstat output show's it is up and listening so there must be another problem with the communication between the two. To troubleshoot this I'd like to get a tcpdump capturing failed attempts to import the contacts. Do so with the following:
yum -y install tcpdump
tcpdump -s 0 -i any host 192.168.201.2 -w output.pcap
Let this run while you try importing contacts. Try all settings - ldap, ad wo/encryption, ad w/encryption(both tls and ssl) and then use CTRL+C to stop the trace after testing and PM me the output.pcap(it can contain sensitive info that shouldn't be publicly posted).
linearstack
Thanks, it worked with the IP address.
