I would like to add users to nagios that can only see some of the servers and have no authority to do any of the administration tasks ( Start / Stop monitoring or alerting ).
NagiosXI user access
Re: NagiosXI user access
Just add then as regular users and check the "read only" box.
Then add these users as a contact to the hosts/services you would like them to be able to see.
Thanks, it worked and am good. you can close the thread.
ClosingJohnsmit wrote:Thanks, it worked and am good. you can close the thread.
