Performance data to csv file
orani
Post by orani »
I have a nagios instalation and a nagiosgraph installation. I monitor the bandwidth of my network connection through a plugin called "check_bandwidth" which monitors the bandwidth of an interface of my fortigate firewall.
I would like to ask if there is any way to export that performance data to a csv file.
Re: Performance data to csv file
Not out of Nagios.
I'm not familiar enough with nagiosgraph to know if there is an interface that allows that (we do not own that project)
orani
Post by orani »
maybe i was not clear. My target is to export nagios data and checks output to a csv file
orani wrote:maybe i was not clear. My target is to export nagios data and checks output to a csv file
I understood your question, the answer was.
scottwilkerson wrote:Not out of Nagios.
and I'll add this.
You cannot export performance data out of Nagios. There is some status data that is available via the JSON cgi but that isn't performance data
orani
Post by orani »
ok. thank you.
orani wrote:ok. thank you.
No problem
