When use check_oracle_health plugin, the tablespace_free got an error?! (refer attachment)
CentOS 7 + Oracle 12.2 + check_oracle_health 3.1.2.1
check_oracle_health plugin problem ...
Re: check_oracle_health plugin problem ...
as this isn't the version we distribute, you may need to check with the author to see if others have reported bugs
the version our install script installs is 1.7.3 this is the one we have tested with our wizards to confirm functionality
The authors website is https://labs.consol.de/nagios/check_ora ... index.html
