I install today Nagio Core 4.3.2 without any problem: all working fine.
Now I have a problem with configuration of monitoring windows host..
I create I file named hosts.cfg under /usr/local/nagios/etc/servers/ like I see into thi guide, I install in my Windows Server NSClient following the instruction into the guide that I fond online but when I launch command /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg the server return me this error:
Nagios Core 4.3.2
Last Modified: 2017-05-09
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for host '' (config file '/usr/local/nagios/etc/servers/hosts.cfg', starting on line 7)
Error: Could not add object property in file '/usr/local/nagios/etc/servers/hosts.cfg' on line 9.
Error: Host name is NULL
Error: Could not register host (config file '/usr/local/nagios/etc/servers/hosts.cfg', starting on line 7)
directives and data definitions. If you are upgrading from a previous
Can anyone please help me to solve the issue?
Many thanks to all
