Feature request for CCM: filter by Active/Not Active, and always have a count of how many things match the filter. Same might be true for Applied/Not Applied.
We're doing some work for a customer where it would be very convenient to be able to do a total count, subtract the active or inactive stuff, and get a count of the opposite stuff as a result (and then cross-check and verify). I'm happy to use the search box similarly to how Gmail does its searching, if that makes it easier. So rather than a "filter button" (and associated text box) taking up screen space, I'm happy to type "is:active" or "is:applied" in the search box and have it print the results. Similarly, one could search for "not:active" or "not:applied" for the inverse.
FEATURE REQUEST: Filter on Active/Not Active
