offline install of log server fails on updating logstash
bpennin
Post by bpennin »
RHEL install of nagios log server fails on below step. This server is blocked from internet access so any resolution would have to be a package that could be installed from the server.
:RedHatEnterpriseServer
7.4
x86_64
Updating Logstash plugins...
Error Bundler::HTTPError, retrying 1/10
Could not fetch specs from https://rubygems.org/
Error Bundler::HTTPError, retrying 2/10
Error Bundler::HTTPError, retrying 3/10
Error Bundler::HTTPError, retrying 4/10
Error Bundler::HTTPError, retrying 5/10
Error Bundler::HTTPError, retrying 6/10
Error Bundler::HTTPError, retrying 7/10
Error Bundler::HTTPError, retrying 8/10
Error Bundler::HTTPError, retrying 9/10
Error Bundler::HTTPError, retrying 10/10
Too many retries, aborting, caused by Bundler::HTTPError
ERROR: Updated Aborted, message: Could not fetch specs from https://rubygems.org/
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'backend'
Reason: Please use [code][/code] tags around long output
Re: offline install of log server fails on updating logstash
The current version tries to reach out to the Internet to update the logstash-input-tcp
Here's what I suggest, from your installation directory run:
cat /dev/null > subcomponents/logstash/post-install
this will skip this step and you likely can proceed with the previous version. This just was a fix for a very infrequently seen bug.
bpennin
Post by bpennin »
Thanks - I will give that a try. Just to clarify - do your cat command then come back and run the ./install command?
bpennin wrote:Thanks - I will give that a try. Just to clarify - do your cat command then come back and run the ./install command?
correct
bpennin
Post by bpennin »
That worked :D Thanks for your help
bpennin wrote:That worked :D Thanks for your help
Excellent, glad to be of assistance...
Locking
