ON console, when i try to see Service Alert History for whatever service, i can see only events for present log file
File: /var/log/nagios/nagios.log
My nagios core is configured to log files under non default path (/usr/local/nagios/var/archives/). Logs are saved on custom folder: /var/log/nagios
But my problem is when i try to browse on console view for previos log history (whith the arrows backwarding), following error appears!
Error: Cannot open log file '/usr/local/nagios/var/archives/nagios-07-02-2018-00.log' for reading!
But from my view that has no sense, because rotation logs are under /var/log/nagios, not under /usr/local/nagios/var/archives/nagios!
root@emonpi(ro):nagios# ls -l /var/log/nagios/nagios.*
-rw-rw-r-- 1 nagios nagios 1052755 Jul 2 17:32 /var/log/nagios/nagios.log
-rw-rw-r-- 1 nagios nagios 1073833 Jul 2 08:17 /var/log/nagios/nagios.log.1
-rw-rw-r-- 1 nagios nagios 1214014 Jul 2 00:17 /var/log/nagios/nagios.log.2My nagios.cfg
permissions seems to be ok for nagios and apache:nagios.cfg
# LOG FILE
# This is the main log file where service and host events are logged
# for historical purposes. This should be the first option specified
# in the config file!!!
log_file=/var/log/nagios/nagios.log
#log_file=/usr/local/nagios/var/nagios.log
root@emonpi(ro):nagios# ls -l /usr/local/nagios/var
total 428
-rw-r--r-- 1 nagios nagios 110407 Jul 2 17:15 objects.cache
-rw------- 1 nagios nagios 153642 Jul 2 17:15 retention.dat
drwxr-xr-x 2 nagios www-data 4096 Jul 2 17:15 rw
drwxr-xr-x 3 root root 4096 Jun 25 22:22 spool
-rw-rw-r-- 1 nagios nagios 156396 Jul 2 17:29 status.dat
drwxr-xr-x 2 root root 4096 Jun 25 22:24 tmpWhere is my mistake? My nagios core is in the last release (Version 4.4.0
) Thanks in advance
