ERROR: Description/Type table : Message size exceeded buffer maxMsgSize.
This is happening on Disk Usage, Memory Usage and Swap usage atm.
I can swear I had this fixed in the earlier version but the upgrade must have undone what I did to correct.
-o, --octetlength=INTEGER
max-size of the SNMP message, usefull in case of Too Long responses.
Be carefull with network filters. Range 484 - 65535, default are
usually 1472,1452,1460 or 1440.
