About nagios XI environment
1) Linux Distribution and version? Centos7
2) 32 or 64bit? 64bit
3) VMware Image or Manual Install of XI? Manual install
4) Are there special configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? SSL
About the problem:
After upgrading to version 5.5 Nagios is asking to authenticate when i navigate to Hostgroup Summary (I already am authenticated). User is also admin so there should be no problems with permissions. When i Click 2 times to Cancel the page gets loaded. /var/log/httpd/ssl_error_log
[Thu Jul 05 09:30:20.682122 2018] [:error] [pid 160839] [client x.x.x.x:51785] PHP Warning: pg_set_client_encoding() expects parameter 1 to be resource, boolean given in /usr/local/nagiosxi/html/db/adodb/drivers/adodb-postgres7.inc.php on line 255, referer: https://nagios.x.x/nagiosxi/
