I'm facing difficulties in choosing services for service dependency as I configured a ton of services with different service names for each host.
So it would be easy to manage the Service dependency if we have an option to filter the services with Hostname also.
Ram
Need Host based service filter for Service Dependency
Re: Need Host based service filter for Service Dependency
I know this would make it easier in your sense, implementing this in the CCM would severely limit the capabilities builtin.
What I would suggest would be to just open a seperate window so you can see them side by side.
Open Bulk Modifications Tool in the CCM
Click "Change a single configuration option"
Click select Services
and in this screen you will have the filter you are looking for, and then you can just select those you need in the Service Dependency window.
I know this is not optimal or what you are really looking for but it is the best I can suggest to help you find what you are looking for
