I'm looking for ways to use check_procs or check_ncpa.py to show critical if the process reached the max threshold inculding the process/service name.
./check_ncpa.py -H ip_add-P 5693 -t 'pass' -M cpu/percent -w 80 -c 90
CRITICAL: Percent was 1.00 %, 1.00 %, 1.00 %, 0.00 %, 0.00 %, 100.00 %, 0.00 %, 0.00 % | 'percent_0'=1.00%;80;90; 'percent_1'=1.00%;80;90; 'percent_2'=1.00%;80;90; 'percent_3'=0.00%;80;90; 'percent_4'=0.00%;80;90; 'percent_5'=100.00%;80;90; 'percent_6'=0.00%;80;90; 'percent_7'=0.00%;80;90;
Check_procs: check every process cpu consumption
paulofrancisco
Re: Check_procs: check every process cpu consumption
The "cpu/percent" will not show you the CPU usage per process.
What kind of systems are you monitoring - Windows, Linux, etc.? You could create your own, custom script for CPU utilization per process, and call it via check_ncpa.py. You can also find such scripts online. For example, there are some 3rd party scripts on the Nagios Exchange that you could try:
https://exchange.nagios.org/index.php?o ... %20process
Once you test the script from the command line, and make sure it works for you, you could create a command and a service in Nagios XI by following the steps, outlined in the document below:
