I seem to have installed the Nagios XI server and its agent "successfully". The agent and monitoring server seem to be communicating but however i am getting this errors in the (/usr/local/nagios/var/nagios.log) Nagios.log file
Error: Could not load module '/usr/local/nagios/bin/ndomod.o' -> /tmp/nebmodCuZJGE: failed to map segment from shared object: Operation not permitted
I suspect this is an error with the NDOutils package.I am also suspicious that the WEB GUI is not showing all the info i expect to see as a result of this.
Has anyone seen this before if so can you help please
in the Nagious Web GUI under notifications i can see all sorts of stuff that i have asked Nagios to monitor in text.These seem to be just snippets or a copy of the nagios.log files displaying in the WEB GUI
I dont think all the other monitoring information is feeding into the GUI well or at all .
I suspect this error is the reason why i am not seeing all informational monitoring stuff (like Disk Uasage, hosts etc ) in a graphical representaions only a few .I also dont see a lot of colourful stuff in green ,red etc as I expected ...Can anyone help please.
Your help would be greatly appreciated.
NDOutils Error:Could not load module '/usr/local/nagios/bin/
Re: NDOutils Error:Could not load module '/usr/local/nagios/bin/
We use ndo2. Did you try and install something else?
ndomod.o is the event broker module component of NDOutils that feeds data out of Nagios Core to another daemon for insertion into MySQL.
What distro and architecture (32-bit/64-bit) did you install Nagios XI on?
I fixed this Nagios didnt like the fact that /tmp director has noexec permisiions on it ..Thanks
