Hi Support,
I have an issue about the Thai language when I report out from the reports menu. Please find the availability.pdf But no issue before export to pdf or jpg.
How can I fix it may be an issue when export only.
Thank you.
export to Thai language not working.
Re: export to Thai language not working.
Reporting runs the report using wkhtmltopdf. Most probably, the font it uses doesn't have the required thai characters. If you searched on Google for "wkhtmltopdf thai characters", you would find many issues. Installing the "missing" package *should* resolve your rendering problem.
FYI, Thai interface is not available as of now (included in Nagios XI), but if could be added in the future. Here's a document on how to contribute to Nagios translations:
https://assets.nagios.com/downloads/nag ... ations.pdf
