An error occurred while attempting to apply your configurati
acentek
Post by acentek »
I am getting the following error when I attempt to Apply Configuration.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Configuration file: 108.59.105.23.cfg successfully written!
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
Error: The description string for service 'VMware, Inc.,VMware-vpxd,6.5.0,8307201' on host 'acegroup-vcenter' contains one or more illegal characters.
Error: The description string for service 'VMware, Inc.,ntp,4.2.8p10,4.ph1' on host 'acegroup-vcenter' contains one or more illegal characters.
Error: The description string for service 'VMware, Inc.,systemd,228,44.ph1' on host 'acegroup-vcenter' contains one or more illegal characters.
Error: The description string for service 'VMware, Inc.,vmware-certificate-server,6.5.0.3536,8157625' on host 'acegroup-vcenter' contains one or more illegal characters.
Error: The description string for service 'VMware, Inc.,xinetd,2.3.15,6.ph1' on host 'acegroup-vcenter' contains one or more illegal characters.
Error: The description string for service 'n/a,VMware-Postgres-server,9.4.15.0,7748409' on host 'acegroup-vcenter' contains one or more illegal characters.
Here is the information that is requested:
CentOS Linux release 7.5.1804 (Core)
64BIT
Manual Install of XI
I do not know what is going on to cause this?
Should I revert to the most recent snapshot?
GldRush98
Re: An error occurred while attempting to apply your configu
Post by GldRush98 »
Go in to Core Config Manager -> Services
Then locate the 6 services there. Update their Description fields to remove the illegal characters. I believe it is the comma that it doesn't like.
Update all 6, then Apply Configuration again and you should be good.
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
npolovenko
Post by npolovenko »
Well said, @GldRush98!
@acentek, Let us know if that resolved your issue.
