Nagios XI upgrade failed
cd ./src/; make install-plugin
make[1]: Entering directory `/usr/local/nagiosxi/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
/usr/bin/install -c -m 755 -d /usr/local/nagios/bin
/usr/bin/install -c -m 755 ../uninstall /usr/local/nagios/bin/nrpe-uninstall
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios check_nrpe /usr/local/nagios/libexec
make[1]: Leaving directory `/usr/local/nagiosxi/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
cd ./src/; make install-daemon
/usr/bin/install -c -m 755 nrpe /usr/local/nagios/bin
/usr/bin/install -c -m 755 startup/default-init /etc/init.d/nrpe
Starting nrpe
NRPE installed OK
Updating NRDP..
IT gave me an error " not complete, do it manually". Can you let me know what I am missing?
Starting nrpe
NRPE installed OK
Updating NRDP..
Re: Nagios XI upgrade failed
It did not throw up any errors apart from this.
I tried manual update as well.however does not give me success message or the failure message.
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nrpe/nrpe-3.2.1/src'
Starting nrpe
NRPE installed OK
Updating NRDP..
Starting nrpe
NRPE installed OK
Updating NRDP..
This issue will be fixed in the next release of Nagios XI. As a "workaround", comment out the following section in the "upgrade" script:
so that it would look like this:
Save, exit, and rerun the upgrade script:
# Uninstall ajaxterminal to install shellinabox
rpmcheck=$(rpm -q Ajaxterm)
if [ $? -eq 0 ]; then
rpm -e Ajaxterm
cp -f "$httpdconfdir/ssl.conf" "$httpdconfdir/ssl.conf.nagiosxibackup"
sed -i '/## AJAXTERM #####################/,+12d' "$httpdconfdir/ssl.conf"
rm -f $proddir/html/admin/ajaxterm.php
fiCode: Select all
#rpmcheck=$(rpm -q Ajaxterm)
#if [ $? -eq 0 ]; then
# rpm -e Ajaxterm
# cp -f "$httpdconfdir/ssl.conf" "$httpdconfdir/ssl.conf.nagiosxibackup"
# sed -i '/## AJAXTERM #####################/,+12d' "$httpdconfdir/ssl.conf"
# rm -f $proddir/html/admin/ajaxterm.php
#fiCode: Select all
cd /tmp/nagiosxi
./upgrade
Last edited by scottwilkerson on Tue Jul 10, 2018 3:16 pm, edited 1 time in total.
Reason: fix incorrect code
can you confirm the below lines to upgrade?
rpm -e Ajaxterm
fi
rpm -e Ajaxterm
fi
I commented the lines you mentioned.
went further and below is the error lines:
Stopping snmptt: [FAILED]
Starting snmptt: Can't locate SNMP.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at (eval 10) line 1.
died at /usr/sbin/snmptt line 426.
Could not load the Perl module SNMP! If net_snmp_perl_enable is
enabled then the SNMP module is required. Please see snmptt.html
for system requirements. Note: SNMPTT uses the Net-SNMP package's
SNMP module, NOT the CPAN Net::SNMP module!
[FAILED]
[FAILED]
Yes, command out this section:
then rerun the upgrade script. Let us know if this helped.
#rpm -e Ajaxterm
#cp -f "$httpdconfdir/ssl.conf" "$httpdconfdir/ssl.conf.nagiosxibackup"
#sed -i '/## AJAXTERM #####################/,+12d' "$httpdconfdir/ssl.conf"
#rm -f $proddir/html/admin/ajaxterm.php
#fiBe sure to check out our Knowledgebase for helpful articles and solutions!
I did comment those lines.
I have got the errors:
[FAILED]
[FAILED]
Is the epel repo enabled on this server? What is the output of the command below?
Can you try installing the perl-Net-SNMP package manually?
yum repolistCode: Select all
yum install perl-Net-SNMPBe sure to check out our Knowledgebase for helpful articles and solutions!
[sadmin@nagios3 ~]$ sudo rpm -ihv perl-Net-SNMP-6.0.1-21.fc29.noarch.rpm
warning: perl-Net-SNMP-6.0.1-21.fc29.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 429476b4: NOKEY
error: Failed dependencies:
perl(:MODULE_COMPAT_5.28.0) is needed by perl-Net-SNMP-6.0.1-21.fc29.noarch
Im trying to download MODULE_COMPAT_5.28.0 but unable to find it
