Unable to connect to system log file
obasnett
Post by obasnett »
Dear Team,
I am a new user of Nagios XI.
I need a plugin and how I can set it up to connect to a log file on a system.
Kindly help with quick resolution.
Contact: Skype name: obasnett
Re: Unable to connect to system log file
This really depends on what you want to do with the logfile, search contents, or check update time, etc.
obasnett
Post by obasnett »
scottwilkerson wrote:This really depends on what you want to do with the logfile, search contents, or check update time, etc.
Thank you for the response.
I want to actually monitor critical error.
Best regards,
My first incline is to recommend Nagios Log Server as this is exactly designed to do this
https://www.nagios.com/products/nagios-log-server/
What defines a critical error may need to be defined.
Depending on the system you can also use something like this plugin
https://exchange.nagios.org/directory/P ... es/details
obasnett
Post by obasnett »
[quote="scottwilkerson"]My first incline is to recommend Nagios Log Server as this is exactly designed to do this
I just setup the nagios log server. However, I am unable to login through the web interface with my credential, although i can login with default credential (username: root password: nagiosls) through putty.
How can I resolve the issue.
Best regards,
