Adding to groups
gloria
Adding to groups
Post by gloria »
hey guys,
i want help. i have 4 different departments which works with different servers. i would like each dpt to only receive alerts for their servers.
currently everyone receives all alerts which people now tend to ignore.
Regards
G
Re: Adding to groups
I would add create a contact group for each department
Add the correct contacts to the contact groups.
Change the host/service configs to reference the appropriate contact groups vs. the current contacts.
gloria
Post by gloria »
i will try that and let you know. thank you so much for your help
gloria wrote:i will try that and let you know. thank you so much for your help
Sounds good!
h4doukeeN
Post by h4doukeeN »
creo que esto es lo que necesitas.
I think this is what you need.
[root@localhost ~]#nano /etc/nagios/objects/contacts.cfg
  GNU nano 2.3.1                              Fichero: /etc/nagios/objects/contacts.cfg
# CONTACTS
define contact{
        contact_name                    nagiosadmin             ; Short name of user
        use                             generic-contact         ; Inherit default values from generic-contact template (defined above)
        alias                           Nagios Admin            ; Full name of user
        email                           [email protected]  ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
define contact{
        contact_name                    axhgarza             ; Short name of user
        alias                           AX  Admin            ; Full name of user
# CONTACT GROUPS
define contactgroup{
        contactgroup_name       admins
        alias                   Nagios Administrators
        members                 nagiosadmin
        contactgroup_name       axhgarza
        alias                   AX Administrators
        members                 axhgarza
        use                     windows-server  ; Inherit default values from a template
        host_name               00-Sv-test     ; The name we're giving to this host
        alias                   Servidor prueba    ; A longer name associated with the host
        address                 192.168.2.188    ; IP address of the host
        max_check_attempts      1
        contact_groups          axhgarza
        service_description     Servicio TV TEST
        check_command           check_nt!PROCSTATE!-d SHOWALL -l TeamViewer_Service.exe
        check_interval          0.1
        retry_interval          1
        notification_interval   1
that should do it
