cant view cluster and index status
benhank
Post by benhank »
When I try to view the cluster or index status page , it is blank. This was happening prior to upgrading to the latest version of NLS and has persisted after the upgrade.
Proudly running:
Nagios Network Analyser
Nagios Fusion
jomann
Development Lead
Re: cant view cluster and index status
Post by jomann »
You probably need to update your /etc/php.ini with a higher memory_limit value. Depending on what you have available on the system, 512M to 1G should be good. You can also check your /var/log/error_log (the apache error log) and see the memory error in there.
benhank
Post by benhank »
that did the trick thanks! you can lock it
Proudly running:
Nagios Fusion
jomann
Development Lead
Post by jomann »
Great, locking it up.
