>> Can you post the nrpe.cfg file from the client machine?
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected])
# Last Modified: 2016-05-10
# NOTES:
# This is a sample configuration file for the NRPE daemon. It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number. The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/usr/local/nagios/var/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# LISTEN QUEUE SIZE
# Listen queue size (backlog) for serving incoming connections.
# You may want to increase this value under high load.
#listen_queue_size=5
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# Note: The daemon only does rudimentary checking of the client's IP
# address. I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1,localhost,<IPofnagiosserver>
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed. This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=0
# BASH COMMAND SUBTITUTION
# to specify arguments that contain bash command substitutions of the form
# $(...). This option only works if the daemon was configured with both
# the --enable-command-args and --enable-bash-command-substitution configure
# script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! ***
# Values: 0=do not allow bash command substitutions,
# 1=allow bash command substitutions
allow_bash_command_substitution=0
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo. For this to work, you need to add
# the nagios user to your /etc/sudoers. An example entry for alllowing
# execution of the plugins from might be:
# nagios ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password. If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEAK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# SSL/TLS OPTIONS
# These directives allow you to specify how to use SSL/TLS.
# SSL VERSION
# This can be any of: SSLv2 (only use SSLv2), SSLv2+ (use any version),
# SSLv3 (only use SSLv3), SSLv3+ (use SSLv3 or above), TLSv1 (only use
# TLSv1), TLSv1+ (use TLSv1 or above), TLSv1.1 (only use TLSv1.1),
# TLSv1.1+ (use TLSv1.1 or above), TLSv1.2 (only use TLSv1.2),
# TLSv1.2+ (use TLSv1.2 or above)
# If an "or above" version is used, the best will be negotiated. So if both
# ends are able to do TLSv1.2 and use specify SSLv2, you will get TLSv1.2.
#ssl_version=SSLv2+
# SSL USE ADH
# This is for backward compatibility and is DEPRECATED. Set to 1 to enable
# ADH or 2 to require ADH. 1 is currently the default but will be changed
# in a later version.
#ssl_use_adh=1
# SSL CIPHER LIST
# This lists which ciphers can be used. For backward compatibility, this
# defaults to 'ssl_cipher_list=ALL:!MD5:@STRENGTH' in this version but
# will be changed to something like the example below in a later version of NRPE.
#ssl_cipher_list=ALL:!MD5:@STRENGTH
#ssl_cipher_list=ALL:!aNULL:!eNULL:!SSLv2:!LOW:!EXP:!RC4:!MD5:@STRENGTH
# SSL Certificate and Private Key Files
#ssl_cacert_file=/etc/ssl/servercerts/ca-cert.pem
#ssl_cert_file=/etc/ssl/servercerts/nagios-cert.pem
#ssl_privatekey_file=/etc/ssl/servercerts/nagios-key.pem
# SSL USE CLIENT CERTS
# This options determines client certificate usage.
# Values: 0 = Don't ask for or require client certificates (default)
# 1 = Ask for client certificates
# 2 = Require client certificates
#ssl_client_certs=0
# SSL LOGGING
# This option determines which SSL messages are send to syslog. OR values
# together to specify multiple options.
# Values: 0x00 (0) = No additional logging (default)
# 0x01 (1) = Log startup SSL/TLS parameters
# 0x02 (2) = Log remote IP address
# 0x04 (4) = Log SSL/TLS version of connections
# 0x08 (8) = Log which cipher is being used for the connection
# 0x10 (16) = Log if client has a certificate
# 0x20 (32) = Log details of client's certificate if it has one
# -1 or 0xff or 0x2f = All of the above
#ssl_logging=0x00
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
#include_dir=<someotherdirectory>
# COMMAND DEFINITIONS
# Command definitions that this daemon will run. Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on! The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory. Also note that you will have to modify the definitions below
# to match the argument format the plugins expect. Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /
#command[check_zombie_procs]=/usr/local/nagios/libexec/check_procs -w 5 -c 10 -s Z
command[check_procs]=/usr/local/nagios/libexec/check_procs -w 150 -c 200
command[check_ssh]=/usr/local/nagios/libexec/check_ssh -H localhost
command[check_swap]=/usr/local/nagios/libexec/check_swap -w 20% -c 10%
command[check_ping]=/usr/local/nagios/libexec/check_ping -H localhost -w 2,2% -c 3,3%
#command[check_mysql]=/usr/local/nagios/libexec/check_mysql.pl
command[check_ntp]=/usr/local/nagios/libexec/check_ntp -H localhost
command[check_usercreation]=/usr/local/nagios/libexec/check_usercreation.sh
command[check_system_pp]=/usr/local/nagios/libexec/check_system_pp
command[check_chrony]=/usr/local/nagios/libexec/check_chrony.sh 1 2
command[check_iptables]=/usr/bin/sudo /usr/local/nagios/libexec/check_iptables.sh -H localhost
#command[check_mountpoints]=/usr/local/nagios/libexec/check_mountpoints.sh -f /proc/mounts /data
command[check_passwd_expiration]=/usr/bin/sudo /usr/local/nagios/libexec/check_paswd_expiry.sh root
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'. This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
>> Also, run the following commands on the client and show the output:
[root@client ~]# /usr/local/nagios/bin/nrpe -V
NRPE - Nagios Remote Plugin Executor
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 3.0.1
Last Modified: 09-08-2016
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available, OpenSSL 0.9.6 or higher required
** POSSIBLE SECURITY RISK - TCP WRAPPERS ARE NOT AVAILABLE! **
** Read the NRPE SECURITY file for more information **
Usage: nrpe [-n] -c <config_file> [-4|-6] <mode>
Options:
-n = Do not use SSL
-c <config_file> = Name of config file to use
-4 = use ipv4 only
-6 = use ipv6 only
<mode> = One of the following operating modes:
-i = Run as a service under inetd or xinetd
-d = Run as a standalone daemon
-d -s = Run as a subsystem under AIX
-f = Don't fork() for systemd, launchd, etc.
Notes:
This program is designed to process requests from the check_nrpe
plugin on the host(s) running Nagios. It can run as a service
under inetd or xinetd (read the docs for info on this), or as a
standalone daemon. Once a request is received from an authorized
host, NRPE will execute the command/plugin (as defined in the
config file) and return the plugin output and return code to the
check_nrpe plugin.
[root@client ~]# ps axuw | grep nrpe
nagios 1117 0.0 0.0 39684 2144 ? Ss Jul05 0:26 /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -f
root 48220 0.0 0.0 103324 900 pts/0 S+ 16:03 0:00 grep nrpe
[root@client ~]# netstat -at | grep nrpe
tcp 0 0 *:nrpe *:* LISTEN
[root@client ~]# /usr/local/nagios/libexec/check_disk -w 10% -c 8% -p /
DISK OK - free space: / 29649 MB (10.93% inode=100%);| /=241397MB;256997;262708;0;285553
[root@client ~]# /usr/local/nagios/libexec/check_disk -V
check_disk v2.2.1 (nagios-plugins 2.2.1)
[root@nklipai01 ~]#
>> How was NRPE installed on the client? What was the guide/tutorial/document that you followed?
I downloaded nrpe and nagios plugins from nagios website and followed steps below:
Upload nrpe and nagios plugin tar files to /usr/local/src/
- Install packages
# yum install gcc glibc glibc-common gd gd-devel make net-snmp openssl-devel openssl unzip xinetd
- Untar files and get inside nrpe folder
# unzip nagios-plugins-2.2.1.zip ; tar -xvf nrpe-3.0.1.tar
- # cd nagios-plugins-2.2.1 ; chmod +x configure; ./configure ; make; make install
- # cd ../; cd nrpe-3.0.1; ./configure
- # make all
- # useradd nagios
- # make install ; make install-plugin ; make install-daemon; make install-config ; make install-inetd; make install-init
- Move all plugin scripts from /usr/local/src to /usr/local/nagios/libexec
# cd ..; mv check_* /usr/local/nagios/libexec/ ; rm -rf nagios-plugins-2.2.1.zip nrpe-3.0.1.tar
- # chown nagios.nagios /usr/local/nagios/ ; cd /usr/local/nagios/; chown -R nagios.nagios /usr/local/nagios/libexec
- # chmod +x libexec/check_chrony.sh; chmod +x libexec/check_iptables.sh; chmod +x libexec/check_mountpoints.sh; chmod +x libexec/check_paswd_expiry.sh; chmod +x libexec/check_system_pp; chmod +x libexec/check_usercreation.sh
- # vi /etc/xinetd.d/nrpe >> Add contents from another server to this file
- # vi /etc/services >> Add “nrpe 5666/tcp #nagios nrpe”
- # vi /usr/local/nagios/etc/nrpe.cfg
allowed_hosts=127.0.0.1,localhost,<ipofnagiosserver>
- Add commands to be checked at the end of the nrpe.cfg
- # service xinetd restart
- verify service is running
