Check BGP Peer State with Mikrotik
achahine21
Post by achahine21 »
Dears,
Kindly note that i'm trying to get the status of a BGP peer between my mikrotik router and my Customer usingNAGIOS.
I tried this plugin:
https://exchange.nagios.org/components/ ... 9&cf_id=29
But i got the below output:
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: .1.3.6.1.2.1.15.3.1.2.192.168.60.17
Error in packet
Failed object: .1.3.6.1.4.1.9.9.187.1.2.4.1.1.192.168.60.17.1.1
Error in packet
Failed object: .1.3.6.1.2.1.15.3.1.12.192.168.60.17
Error in packet
Failed object: .1.3.6.1.2.1.15.3.1.13.192.168.60.17
expr: syntax error
expr: syntax error
expr: non-integer argument
line: neighbor:192.168.60.17:sent::received:
./check_bgp_neighbors.sh: line 107: [: -eq: unary operator expected
Failed: status: prefixes: sent: received:
It's look like the problem is related to the OIDs, but i'm not able to find any new OIDs or new scripts.
Please let me know if there's any other way to get the status of BGP Peer with mikrotik router.
Re: Check BGP Peer State with Mikrotik
That message usually points to the device not responding to the OID's so you may want to verify that it is setup to be polled by SNMP and that is there are any settings that have to be enabled in the device, make sure they are.
Also, take a look at this link for more things to try.
http://www.net-snmp.org/wiki/index.php/ ... cations_09
Last, check with the manufacturer to see if the BGP status can be viewed by SNMP.
